#41 |
![]() Join Date: Sep 2004
Thanks Richpin!
Would you have a video on how to replace the rack and pinion? |
#42 |
New Videos
Turn Signal Flasher Replacement http://youtu.be/mEJ7RqYvG1M How To Follow Wiring Diagrams http://youtu.be/UbsiKI4upBM Brake Light Strobe Module http://youtu.be/SBilxVmZijU
http://www.youtube.com/richpin06a |
#43 |
New Videos
Horn Button Replacement http://youtu.be/Rhb9Euk90rE Led Dome Light Conversion http://youtu.be/ovEVxhFVtSE Sequential Arrows for Side Mirror Turn Signal Part 1 http://youtu.be/DpfHxMTge4Y Sequential Arrows for Side Mirror Turn Signal Part 2 http://youtu.be/B_XMzMi9RIA Sequential Arrows for Side Mirror Turn Signal (epilogue) http://youtu.be/6w1rSyNBmVU
#44 |
![]() Join Date: Mar 2012
As I'm looking through these video's for something in particular and it doesn't seem to be here I'm wondering you you happen to have any video's on the master cylinder in a 98 saturn sl 1.9l SOHC? I seem to have a leak at the firewall. It's a very slow leak but I would like to get it taken care of and was wondering if maybe there is a gasket or something that I could replace? My brakes seem to work just fine and I have inspected the mater cylinder and there are no leaks anywhere except at the firewall location. Just wondering if I need to replace the whole master cylinder for this or if I can just replace a gasket or something? Thanks so much for all your video's they are my savior as a back yard mechanic learning to be a real mechanic..lol
#45 |
New Videos
Emergency Windshield Wiper Switch http://youtu.be/5q8Y5NJ4kiU Autoranging Multimeter Review http://youtu.be/Ln59xlYvaaM Spark Plug Cleaning http://youtu.be/1EoeB1KUHUc Troubleshooting Blower Motor Only on High Speed http://youtu.be/ihBYh8jc7dM
#46 |
![]() ![]() ![]() Join Date: Dec 2012
2000 SL2
Man I wish I lived closer to you. I'd love to stand in the corner of your garage absorbing all your awesomeness in Saturn repairs.
Your videos have helped so much. Trips to the junkyard are a 10 minute job with only the wrench sizes I need. No more 3 hours and a whole toolbox sitting there trying to figure out how to take something off. |
#47 |
New Videos
Coolant Level Light Troubleshooting http://youtu.be/-ROFZasl9BU Shift Indicator Bulb Replacement http://youtu.be/Dxjv0HBFd9U Sway Bar Bushing Replacement http://youtu.be/yIoA4e2Q58I
#48 |
New Videos
Gen 1 Door Glass Removal http://youtu.be/9woThmootVE Trailer Hitch Installation http://youtu.be/CKOSbXRhiBU
#49 |
I'd love to see more 1st Generation R&R videos. Mainly for things that are very different from the 2nd Gen.
And specially for 1st Gen coupes ![]()
1992 SC - TwinCam (Automagic) Bought it brand new, and still loving it today. |
#50 |
New Videos
Clutch Hydraulic Release System Removal http://youtu.be/Hz9wQDofkaU Battery Box Removal http://youtu.be/WMbGi40WQSk Battery Replacement http://youtu.be/jYlkDdh0gQE
#51 |
New Videos
OBD2 Vehicle Memory Saver http://youtu.be/CWQXGPp7i0E Gen 3 seatbelt removal http://youtu.be/3Vijx1x2HW4 Saturn Vue Accelerator Pedal Position Sensor Removal http://youtu.be/9hD4qSdXnOc Saturn 00-02 BCM body control module) Removal http://youtu.be/O-3AARRikho
#52 |
![]() Join Date: Nov 2013
1993 SC2
1998 SL
great repair videos... im replacing my clutch on my 93 sc2 , would you having any videos of that ....thanks
#53 |
New Videos
Thermostat Replacement 2 http://youtu.be/dVLoeoDU5E8 How To Remove Stuck Rusty Wheels http://youtu.be/h5isxm-u154 Door Handle Push Pin Removal Tool http://youtu.be/qhpHR3MSHfI Gen 3 Multifunction Switch Removal http://youtu.be/-gVM4PsRylk
#54 |
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2010
2005 VUE 2.2L
Thanks for your continues service to the community of Saturn owners!
I really like your video showing how to set up a strobe on the 3rd brake light. Can you ad some detail on exactly how you wired the 'bypass' switch? type of switch you used? and maybe even why you felt it was a good idea. Are you aware of states where the strobe is not approved??
Mark '05 Vue, '02SL1, '01SC2a, '01SC2b, '99SL1 :::::> '04 SVT Cobra, '67 Mustang Vert. |
#55 |
![]() Join Date: Apr 2014
2001 SL2
Know anything about a Satun SL2 2001 with an error code P0300?
#56 |
Hey Rich,
Do you have any video's of axle shaft replacement? It's a 1997 sl2. Thank you very much! |
#57 |
New Videos
Homemade Transmission Jack http://youtu.be/5H_J7C93k-w Sway Bar Split Bushing Replacement http://youtu.be/rmOanLT_gQ0 F-5 F-2 Fuse Box Fix http://youtu.be/bE-HbjrIQSs Fuel Pump Amperage Draw Test http://youtu.be/JgoUxYR2e4k
#58 |
New Videos
Automatic Transaxle Range Switch Adjustment http://youtu.be/vjwxw8A08Sw Saturn ION Instrument Cluster Bulb Replacement http://youtu.be/EGcG9fWNTYg How To Drive Up On Car Ramps http://youtu.be/fKNp331F-dM Power Window Motor & Regulator Removal http://youtu.be/XkfZlQ5sp50
#59 |
New Videos
L Instrument Cluster Removal http://youtu.be/Dv4EBpssgaU Automotive Ignition Module What's Inside http://youtu.be/Af7OxUd19bw SL,SC,SW Starter Replacement http://youtu.be/YRqE9cqnn7g
#60 |
New videos
Heater A/C Control Bulb Replacement (updated) http://youtu.be/UOZsfnEMbp4 How Does A Relay Work http://youtu.be/H48FFI0W7jQ Heater Core Removal http://youtu.be/vCZorrWXGv4 Ion Radio Removal http://youtu.be/b6T5_U9KSTI
Bookmarks |
watching Richpin's GPS video | dorisSL | S-Series Tech | 5 | 01-29-2009 01:55 AM |
richpin's video - battery hold down removal | bez | S-Series Tech | 14 | 10-15-2008 11:51 AM |
Videos of Astra!! | alfkorda | Astra General | 5 | 12-18-2006 04:51 PM |
0-60 videos | golftango | Ion General | 31 | 10-07-2003 08:30 PM |
Installation videos | sc288203 | Mods and Performance | 6 | 05-06-2003 04:04 PM |
