Old 07-28-2012, 01:28 PM   #1
n8rg8r
n8rg8r is on a distinguished road
Default 05 Ion - "key/ignition cylinder" issue - not fully turning
Hi, I have an 05 Ion and am having an issue with where I put the key into the ignition. I've had this part replaced recently but is till causing me problems on occasion. I can put the key in, turn it forward and start the car. I've never had a problem with that. But, on occasion, when I turn the car off, rotate the key backwards, sometimes it sticks in the middle position and won't rotate back fully and allow me to remove the key.
I've recently had this "part" replaced by a local dealership, but I'm still having this problem on occasion.
It is "better", but I'd think this shouldn't happen at all...ever.
Any thoughts or comments about this would be greatly appreciated!!
n8rg8r is offline   Reply With Quote
Old 07-28-2012, 05:24 PM   #2
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Default Re: 05 Ion - "key/ignition cylinder" issue - not fully turning
We don't like Ions on this forum. Try next door --> Ion forum
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 07-28-2012, 05:44 PM   #3
If the key and cylinder are both new and the key is a dealer cut key then a very small amount of powdered mica lube should fix it. If it is not a dealer cut key then the first thing to do is get a new key cut.
Old 07-30-2012, 11:44 PM   #4
Zosozeppelin
Zosozeppelin is on a distinguished road
Zosozeppelin's Avatar
2006 ION-3 Quad Coupe
As for the cylinder issue, they're known for being picky. Do as Oldnuc suggested, and if it comes down to it, you may have to have it replaced again. Supposedly GM came out with a new design for it (and I hope the work is under warranty still). They usually only act up in cold weather though, so it is in all odds the key. As previously stated, have the dealer cut you a new key and it should work. Switching my key out to my spare solved the problem for me.
Elizabeth
'06 Level 3 Quad Coupe. 140K as of 5-3-15. Traded for 2015 Chevy SS. Gone but not forgotten.
Current: 2017 2LT/RS 50th Anniversary Camaro
Zosozeppelin is offline   Reply With Quote
97 sl "studders" or "jerks" when turning right chinkey1234 S-Series Tech 5 05-25-2012 11:14 PM
Can Ignition Coil be "bad" even if tests in "good" range? saladdin S-Series Tech 3 11-06-2011 03:08 PM
Saturn Ion "groaning" when turning the steering wheel? JOE PA Ion General 6 01-08-2010 02:21 PM
3.5L water temp "fully warm" position? ls3ftw Vue Tech 6 09-10-2009 10:08 PM
VUE Steering wheel "popping sensation" when turning slowly MarkW Ion General 6 06-26-2002 05:19 PM
