Old 05-21-2012, 11:29 AM   #1
hortonbayhunter
hortonbayhunter is on a distinguished road
2001 SW2
Default SW2 Drivers Seat
I just purchased a 2001 SW2. I love the car but the Drivers seat back is NOT able to adjust to fully upright. There is always too much of a back tilt to it. This is NOT true of the passenger seat. I went to the junkyard and found the same true on other SL1s.
After driving for more than 20minutes my previously injured hip is in pain. I do not have this problem in other cars or when I ride in the passenger seat.
1. Can I change the adjustment to make it more upright?
2. Was an electric seat ever made for this car so that I could replace it with an electric seat?
3. I saw a post about a passenger seat being put in the drivers position, but it did appear to be complicated.
4. Are there OEM manuf. that make better seats for this?
5. Other ideas? I have tried seat pads, etc. they dont fix the problem because they don't make the back more vertical, but simply add padding.
hortonbayhunter is offline   Reply With Quote
Old 05-21-2012, 11:49 AM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Default Re: SW2 Drivers Seat
There is no adjustment to the recline mechanism. I don't know if different years had different degrees of tilt. If they do, the recliner mechanism would be bolt-on.
None were made.
Parts of a passenger seat can be used, but some parts from the driver's seat have to be used. The recliner mechanism doesn't swap, as the adjustment handle would be on the wrong side & hit the console.
None that bolt right in. Just about any seat could be used with some fabrication of brackets (though obviously some would fit the space/height better than others.)
I've found a lot of people spend some time fighting against sitting in the more reclined position that fits these cars better than trying to sit more upright. For most people, there's a learning curve of realizing how to relax and recline, and once that change of mindset & habit occurs, they're very comfortable seats. However, I don't know that that would be true when the position is provoking an old injury like yours is. Unfortunately, I'm not sure what to suggest for you.
SaturnSeries.net owner
Old 05-21-2012, 12:20 PM   #3
hortonbayhunter
2001 SW2
Thanks for your information. It helps me narrow down my options.
Corbeau makes a seat bracket and seat for this car - I think. They are not cheap, but I really love this car.
One additional question.
Is the 2001 SW2 driver seat the same bolt pattern as the SC and SL's for 2001?
Old 05-21-2012, 12:38 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Yes, the front seats will swap between all models, years, and trim levels of S-Series. You can take seats from any '91 and bolt them into any 2002 (though it would require swapping the seatbelt buckle.) I'm pretty sure a 2001 SW2 driver's seat would be completely identical to an SL2 driver's seat.
Old 05-21-2012, 12:57 PM   #5
hortonbayhunter
2001 SW2
Thanks again! You really helped me determine my options.
I think I will look into the Corbeau seats and brackets!
Old 05-21-2012, 02:21 PM   #6
Post up pics and a review if you like them!
Brackets are a bit spendy at $99 each
SC-1 / SC-2 94-01 D1056T D1057T
http://www.corbeau.com/service/seat_brackets/
Seats look nice. Link to sports seat
http://www.corbeau.com/products/recl...ats/sportseat/
So if I decide to get a pair of new leather seats for my SC2, that's $1200 - for a $400 car
I'd expect the frames to be stronger, thought, which is a good thing
Old 05-21-2012, 02:33 PM   #7
hortonbayhunter
2001 SW2
I talked to them and I can order 1 cloth seat ($299) and 1 bracket($99) and shipping is approx ($70). So just under $500. My car is worth about $1,500 so your question is valid. But, $500 is perhaps 3 months payments on a new/newer vehicle and I expect it to last longer than 3 months, although something else could go wrong before that time. Thanks, again for the info and questions.
Old 05-21-2012, 04:48 PM   #8
Oh, don't misunderstand me I'm actually thinking somewhat seriously about it (I'd probably do what you are doing, get cloth rather than leather)
I love these two little plastic cars, too
Purchase price <> car worth - I've had my SL2 for about 40k miles. If I drive it another year, the gas savings over my previous commuter will have covered the purchase price of the car.
The bugger is so reliable and cheap to maintain that I expect to drive this car for at least 10 years (should put me close to 300k miles) - and I feel perfectly comfortable with PL/PD so there's some insurance savings, too. The SC2, I plan to completely restore.
Old 05-21-2012, 05:02 PM   #9
PurdueGuy
PurdueGuy's Avatar
1999 SC2
1999 SC1
Another good thing to consider is that if, for example, a year down the road a rock falls off a truck, lands in the road, punctures your oil pan, and your engine locks up, and you decide not to fix the car, that doesn't mean your nice Corbeau seat(s) suddenly have no value. The same nice seat might find a home in your next car, and maybe even beyond that. I've got a CD player that's been that way, it's 13-14 years old now, and has served me well in about a half dozen different cars. You might have to buy a new seat bracket if you get something other than another S-Series, but at least you would know you have a comfy seat.
Old 05-21-2012, 05:59 PM   #10
If the leather is the same quality as stock '93 leather, don't bother paying any extra over cloth seats for them. They do look nice but unless you drive well under the speed limit it feels like your sitting on an ice rink with how you slide around. Then the leather is colder in the winter and much much much hotter in the summer then cloth.
adjustment, driver, seat
Mesh Support under drivers seat... (common caved in drivers seat) mattachuz L-Series General 8 02-12-2012 06:22 AM
The Drivers seat Bevraffaele Vue General 2 01-17-2010 06:22 PM
pass. seat track on drivers seat? fetchitfido S-Series Mods 4 10-04-2006 10:40 AM
WTB..Need Drivers Seat White93SC2 Classifieds 0 07-18-2004 10:41 AM
Drivers seat GRIFF S-Series General 4 09-14-2003 08:00 PM
