#21 |
Updated Videos
Saturn s-series Fuel Pump Troubleshooting 2 http://www.youtube.com/watch?v=lqlBWRMwN_o Door Window Glass Removal http://www.youtube.com/watch?v=WMA7Obtwe0c
http://www.youtube.com/richpin06a |
#22 |
New Videos
Trouble Code P0404 EGR Cleaning http://www.youtube.com/watch?v=bt5lRTt6BsU Automotive Ramp Extensions http://www.youtube.com/watch?v=YFLtoA2Klks Removing Self Retaining Air Duct Clamps http://www.youtube.com/watch?v=dJ91oYavwy0 Radiator Replacement http://www.youtube.com/watch?v=4nUyGjeLpVs Updated Videos Serpentine Belt Tensioner Removal http://www.youtube.com/watch?v=Or0-0oG5Hsc
#23 |
Updated Videos
Cleaning A/C Drain http://www.youtube.com/watch?v=W0VdFRDdgvA Door Lock Cylinder and Door Panel Removal http://www.youtube.com/watch?v=BoxTGyVCXX8
#24 |
New Videos
P0340 & P0341 Trouble Codes troubleshooting http://www.youtube.com/watch?v=i_y-3fhAHZM Automotive Cylinder Leak Down Tester,How To Build http://www.youtube.com/watch?v=7UcOn8OEt0Y Multifunction Switch Replacement http://www.youtube.com/watch?v=pz3UIzmK7T8 Fuel Pump Troubleshooting (ground) http://www.youtube.com/watch?v=uo5OeHcvk-0 Wiper Motor & Switch Troubleshooting http://www.youtube.com/watch?v=0KHUxiXn31s
#25 |
New Videos
Security Starter Relay System http://www.youtube.com/watch?v=UfaOOAOXUHE Exhaust Flex Pipe Replacement http://www.youtube.com/watch?v=IZYcr50m750 Car Will Not Start http://www.youtube.com/watch?v=Zjstj9kWos0 Clutch Interlock Switch Troubleshooting http://www.youtube.com/watch?v=xsfuFcMqvjM Homemade Air Conditioner Vacuum Pump http://www.youtube.com/watch?v=DOq0Tr6QTa8 Windshield Washer Troubleshooting http://www.youtube.com/watch?v=gRsOefRDaqs Shifter Boot Replacement http://www.youtube.com/watch?v=RP06_Ax38rE
#26 |
![]() Join Date: Aug 2009
Why are you deleting so many of the videos? Does youtube have a capacity?
#27 |
![]() ![]() ![]() Join Date: Jun 2004
you tuibe doesn't even work for me anymore. i get sound & no picture. when i try to log in i get a screen asking me to join google & they will link both accounts. when i try to join google i get that dam code where you have to put it in to avoid spam & i never can read the code & then i can't log in. what a pain...
#28 |
New Videos
2nt design Engine Mount Sag Measurement http://youtu.be/U50UGSq_AVo Windshield Wiper Motor Removal http://youtu.be/KaKXFcDI2rU Exhaust Hanger Removal http://youtu.be/An1MPa2CwzY
#29 |
New Videos
SW Rear Wiper Arm Removal http://youtu.be/ssxYwo4Tx0U Rear Door Glass Removal http://youtu.be/-6cKbTwdFOg Intermediate Axle Support Bearing Squeak http://youtu.be/5wgyiAKv3HU Three to Two Wire Horn Conversion http://youtu.be/XZTPU8G5iM8
#30 |
![]() Join Date: Oct 2005
1997 SL1
2001 SW2
The blower motor removal is dead, and has an update:
http://www.youtube.com/watch?v=6mCop...el_video_title
2002 Saturn L200, I4, Auto with ~173,000. Bought 9/24/2013 with 156,107 miles for $2200. 1998 Toyota Camry with ~175,000. Bought 2/1/2015 with 173,523 miles for $1800 |
#31 |
![]() ![]() Join Date: Nov 2010
Location: Pacifica by San Francisco – 5sp – Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
1996 SL2
Clutch: How to install the Throw Out bearing on a SL2 5-sp transmission:
http://www.youtube.com/watch?v=b817j8O12TA |
#32 |
1996 SL2
Engine rebuild videos for 96 DOHC
Starting from engine block bearings to crank caps. Part 1 http://www.youtube.com/watch?v=OmdoiynULhc Installing crank caps and torquing Part 2 http://www.youtube.com/watch?v=qPOx5evoCAI Rod to piston work Part 3 http://www.youtube.com/watch?v=wklAB5PKQO0 Installing rings on Pistons Part 4 http://www.youtube.com/watch?v=kYmkZNElrjU |
#33 |
1996 SL2
Installing the Rear Seal Carrier for 96SL2
http://www.youtube.com/watch?v=96nBoHWOzO4 |
#34 |
New Videos
Fuel Gauge Troubleshooting http://youtu.be/euIL8M2d2L0 Gas Gauge Reads Too Low http://youtu.be/De0_O6QOgH4 Trouble Code P0717 http://youtu.be/Y-I7iw8km_c Automatic Transmission Fluid Filter Change http://youtu.be/vEimWgEb65c Front Stabilizer Bar Replacement http://youtu.be/MPr3QnbqMpY Fuel Tank Strap Replacement http://youtu.be/tgTIQL4H05A Jack Stand Placement http://youtu.be/82sT4tjXLNI Bottom Dogbone Motor Mount Replacement http://youtu.be/sRGBDRGA5t8
#35 |
New Videos
How To Use A Multimeter http://youtu.be/zb7WHaL_dz8 Brake Bleeder Removal http://youtu.be/RMVV51gyoPU Automotive Computer Radio Memory Saver http://youtu.be/IXELDLBbmoU Battery Load Tester http://youtu.be/tVHlG9qgr8k Head Gasket,Water Pump Replacement Part 1 http://youtu.be/yH0gHdnM1cE Head Gasket,Water Pump Replacement Part 2 http://youtu.be/UHj4iHThY2k
#36 |
New Videos
Locking Extension Bar http://youtu.be/m0hWyk1hcGI Copper Antiseize & Saturn Serpentine Belt Tool http://youtu.be/n5ZgzTAoExM Saturn Trunk Lock Cylinder Removal http://youtu.be/unT-PhT6cig Saturn Stick Shift Shifter Cable Bushing Replacement http://youtu.be/AI3h7uSTvAI
#37 |
New Videos
Steering Gear Removal and Replacement http://youtu.be/1KMaV1kFdzk Back Up Light Troubleshooting http://youtu.be/tdRxwhjYjAY Fuel Door Repair http://youtu.be/2Y77nsmNxtc Chime Module Replacement http://youtu.be/-n4acS2DJkM Engine Coolant Temperature Sensor Resistance Checking http://youtu.be/wFHWpgHMAvY
#38 |
Updated Videos
Ignition Lock Cylinder Replacement http://youtu.be/Yt8wnj4qHoc Throttle Position Sensor Replacement http://youtu.be/Na6Hgu2qwLg Power Steering Pump Replacement D.O.H.C. http://youtu.be/OOz4MolBoGI
#39 |
![]() Join Date: Jun 2012
hey rich u are assome!! i have a problem with my instrument panel. last night my son turn the key to whine the windows up and left the key turned on and kill the batt. this morning i jumpped started it and now none of the gauges work,speed,tach,fuel,temp,none of the idot lights come on either. the only light that comes on isthe securety light then goes out like it supposed to. i checked the fuses all are good. so any idea of what i could do with out taking it to the dealer. there is no codes . i am stumped .please help
#40 |
New Videos
EVAP Purge Solenoid Testing http://youtu.be/VmfiI1ribdM Seat Repair http://youtu.be/v2k8qPoB8cI Ignition Lock Cylinder Cleaning http://youtu.be/8iLPpXVElU0 Water Pump Pulley Bolts Torquing http://youtu.be/o4EklQb6Bl4
watching Richpin's GPS video | dorisSL | S-Series Tech | 5 | 01-29-2009 01:55 AM |
richpin's video - battery hold down removal | bez | S-Series Tech | 14 | 10-15-2008 11:51 AM |
Videos of Astra!! | alfkorda | Astra General | 5 | 12-18-2006 04:51 PM |
0-60 videos | golftango | Ion General | 31 | 10-07-2003 08:30 PM |
Installation videos | sc288203 | Mods and Performance | 6 | 05-06-2003 04:04 PM |
