Old 11-28-2019, 01:19 PM   #6341
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
Originally Posted by bumpdraft View Post
Turn signal quit working, so I removed the bulb and the contact fell out
It appears it corroded:
Thanks to prepper hoarding, I have a few spare tail light wiring harni around here somewhere so I can restore the joy of being a perfect, courteous driver who uses a turn signal, even though doing so can be interpreted as a sign of weakness. I am willing to take that chance for the driving community
Until it is fixed you could always use the old arm signals, unless of course, you are too young to have used them in the past.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-28-2019, 05:06 PM   #6342
bumpdraft
bumpdraft's Avatar
1998 SW2
I fixed it immediately. I wouldn’t drive that thing without it.
They only use one type of hand gesture in these parts Driver’s around here are barely able to interpret turn signals. Half of them see a blinking light on the small car ahead as a sign to start tailgating even closer — “Turn signal use is a sign of weakness. — MUST_DOMINATE
Add to bumpdraft's Reputation
Old 12-04-2019, 10:46 PM   #6343
s-petersen
s-petersen is on a distinguished road
2002 SL1
1994 SL2
Blinker relay, smog pump, working on EVAP sensor in gas tank
251,000 this week
1994 SL2 with 220,000, 1994 SC2 with 128,000 Both had reverse slam,SL2,fixed with nuts,SC2 needed valve body-sold,2002 SL1 251,000 needed cat, 1998 Ford Ranger 160,000 1994 SC2 166,000 parts
Add to s-petersen's Reputation
Rate the quality of this post and help s-petersen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
s-petersen is offline   Reply With Quote
Old 12-04-2019, 11:36 PM   #6344
98_Gold_Uranus
98_Gold_Uranus's Avatar
Before I left work, I removed, wet sanded, buffed, and reinstalled the 21 year old headlights on the 98.
Far from perfect still, but WORLDS better than before. SO much more light output. I can actually see a beam pattern projecting ahead of the car now instead of just a hazy glow lol
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-05-2019, 12:42 PM   #6345
This past weekend - cut off the old resonator / mid pipe, put high-temp POR15 over the flange and welds of the new aftermarket one, sprayed high temp paint over it, and installed
http://www.saturnfans.com/forums/sho...59#post2311259
Apparently, I've had a loud exhaust since about May based on an earlier post of mine in this thread. It's nice having a fully quiet exhaust again - didn't realize that having a loud exhaust was adding a low level of stress/anxiety to my commute.
Old 12-05-2019, 02:04 PM   #6346
Claybury
Claybury will become famous soon enough
Claybury's Avatar
I haven't done this yet. Just bored today and I noticed I have some rolls of vinyl that are getting old sitting on the shelf. A quick Paint sketch latter....
I could always peal it off once I get sick of it. Think anyone would notice me coming?
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Add to Claybury's Reputation
Rate the quality of this post and help Claybury reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Claybury is offline   Reply With Quote
Old 12-05-2019, 06:47 PM   #6347
focusofheart
I had been hearing a clunk, periodically, from the front end for a short time, so I did a lot of research into this forum and watched many youtubes to help me uncover the problem before it got out of hand.
I ended up lubricating the front sway bar bracket bushings, using a spray silicone, several times over two days and the clunk is gone and the problem uncovered.
I have ordered the bushing/bracket kit and since I have a 15mm socket I think I can do this myself or at least make a Chocolate Eclair Cake to bribe my hubby to help.
Old 12-10-2019, 10:47 AM   #6348
bumpdraft
bumpdraft's Avatar
1998 SW2
98 Gold Uranus’ post (above) prompted me to fix the leak in the driver’s headlight.
First, I pressurized it and washed it with soapy water to find the leak.
After it was dry, I pulled a vacuum and applied silicone caulk.
This morning, in suggested videos, some evil, because “Internet”:
(No, I am not talking about Scotty. He was just unlucky to be next to the evil video )
Old 12-10-2019, 04:14 PM   #6349
Zeebins
Zeebins's Avatar
Put in a new wiper motor this morning. The last one I was pulled from a junkyard but this one i got from Advanced Auto for $54. It’s cheaper than what I could have gotten on RockAuto and it has a life time warranty.
I also cleaned out the 2 rubber drains while I had it apart. There was a lot of dirt packed into them. They probably weren’t doing much at all. I’ll get to fixing the vent screen someday
File Type: jpg D8B9BFD1-A363-431D-BB44-2A46726064E0.jpg (124.0 KB, 8 views)
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Zeebins is online now   Reply With Quote
Old 12-11-2019, 11:42 AM   #6350
SLfun
SLfun will become famous soon enough
2006 ION Red Line
Today I removed the ECM that I installed yesterday because the 99 ECM won't play nice with the 95 injectors I have in the motor. It was a fun task outside with the temps well below 0 this morning
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLfun is offline   Reply With Quote
Old 12-12-2019, 01:01 PM   #6351
Pitcher
Pitcher's Avatar
Rain-X on the Windshield.
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pitcher is online now   Reply With Quote
Old 12-12-2019, 07:52 PM   #6352
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Despite replacing the sway bar, the control arms and their bushings recently, I've been hearing some clunking and groaning on the passenger side. My plan was to remove, disassemble and reassemble the strut and strut mount but in the spirit of K.I.S.S. I thought I'd try the silicone spray on the sway bar bushings first.
They are a lot quieter now, but then again, my bushings aren't quite seated properly in the sway bar bracket-- next on my list.
Add to Goggles Pisano's Reputation
Rate the quality of this post and help Goggles Pisano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Goggles Pisano is offline   Reply With Quote
Old 12-13-2019, 07:14 PM   #6353
focusofheart
This was my 'clunk' that was fixed today with new sway bar bushings and brackets. Silicone grease was then applied to all bushings while the car's skirt was hiked up.
They lasted 21 years
Old 12-13-2019, 08:18 PM   #6354
Zeebins
Zeebins's Avatar
Swapped out the orange turn signal bulbs with chrome painted ones that are still amber when on. They're more red than amber imo, but they look a lot nicer when off.
Powered by Plastic
Old 12-14-2019, 12:55 PM   #6355
Pitcher
Pitcher's Avatar
...skirt was hiked up.
Love it!
Old 12-14-2019, 01:54 PM   #6356
focusofheart
My shift lever was having a little problem getting out of park, so I learned what to do from this forum and grabbed a Philips, a couple different sprays and ended up taking the console off to clean and lubricate the solenoid.
So far, so good.
At least I am now aware of the 'bypass' so I can start my car when the time comes to replace the solenoid.
Thank you FORUM!!
Old 12-14-2019, 03:06 PM   #6357
454cid
My car did that just the other day.... I assumed it was snow/ice or possibly a linkage/cable going bad. I'll so a forum search and see what info I can find before it really causes me trouble.
1999 Chevy K3500
Add to 454cid's Reputation
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
