Old 03-11-2007, 06:57 PM   #1
yazhere
yazhere is on a distinguished road
yazhere's Avatar
Default Code 26 / Auto trans to manual swap
I have completed an auto to manual transmission swap for my 1995 SL. Donor car is a 1995 SL1. I also swapped the PCM. Installed a clutch safety switch utlizing the two purple neutral safety wires. Used the pink and lt. green wires for the reverse light switch. The 1995 SL had no code issues prior to the swap. The car and manual works great however I have a code 26. I have used the troubleshooting QDM from DIFFERENT RACING and the PCM J2 Pinout. I tested through the troubleshooting but do not seem to get correct readings from the J2 Pinout A2/Speedout, A9/VSS Hi, and A10/VSS Low
LoSaturn posted this in a prior thread:
When I did the auto to manual swap in my 95, I had to run a wire from the back of the cluster to the in-line body harness connector. I just went to the junkyard and cut off a gauge cluster connector and brought it home. Carefully removed one of the pins out of the connector and plugged it into my cluster connector in the correct location. Then ran the other end to the in-line body harness connector located behind the drivers side kick panel. You dont absouletly need it, but you will get a check engine light without it.
Could this be the problem?
yazhere is offline   Reply With Quote
Old 03-11-2007, 07:23 PM   #2
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: Code 26 / Auto trans to manual swap
Heck of a time for Low Saturn to be on vacation.......
Old 03-12-2007, 10:19 PM   #3
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Its beacuse of the upshift light circuit not being connected. Thats the cause of the code 26.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 03-13-2007, 09:04 AM   #4
richpin06
richpin06's Avatar
just the guy yaz wanted to see..................
Old 03-13-2007, 10:14 AM   #5
yazhere
yazhere's Avatar
That's what I thought it was by looking through the wiring diagrams.
Manual PCM A2 Speedout to Center Console / IPJB Conn #4998 PIN D should exist. The problem is there is no connection/ dk grn-wht wire from the instrument cluster/speedometer & electronics ( A ) to the IPJB Conn #4998 PIN C.
The beauty of this project is I have a donor car in the garage right next to the '95 SL. As you can expect, the donor car is slowly becoming a complete teardown like Low Saturn has shown to where the frame is cut up and stacked.
Thanks for the messages Richpin and confirming Low Saturn.
Old 03-13-2007, 10:40 AM   #6
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Exactly. Just run a wire from the needed position from the back of the instrument cluster to the PCM side of the inline body connector behind the drivers side kick panel and you're done. It literally took longer to get the top dash panel off than it did to connect and run the wire. Just remove a length of wire with the pin still attached from your donor cars instrument cluster wiring.
Mike
-1991 Turbo SL2.
Old 03-13-2007, 12:26 PM   #7
yazhere
yazhere's Avatar
Wire confiscated from donor to be implanted.
Old 03-13-2007, 12:40 PM   #8
richpin06
richpin06's Avatar
This sounds like a Frankenstein movie.Where the good doctor yaz is implanting evil things in the poor old monster...............
auto to manual trans swap BigMike0206 S-Series General 15 07-22-2009 10:24 AM
96 sc1 auto to manual trans swap dcc81187 S-Series Tech 2 05-19-2009 11:24 AM
1994 Sohc Auto To Manual Trans Swap Teddyg_123 S-Series Mods 3 05-16-2009 07:23 PM
Auto/manual trans swap ? TomM96 S-Series General 6 04-19-2008 05:00 PM
How hard to swap auto trans to manual? ym42 Miscellaneous Tech 4 06-08-2004 03:23 PM
