Old 10-11-2006, 07:09 PM   #1
scarecrow0529
scarecrow0529 is on a distinguished road
scarecrow0529's Avatar
1992 SC2
Default when to use a hotter plug
i was wondering i had a bunch of work done on my engine like the head has been ported polished, shaved, bored etc. when should i use a hotter plug.
scarecrow0529 is offline   Reply With Quote
Old 10-11-2006, 07:21 PM   #2
Default Re: when to use a hotter plug
These are pretty significant performance mods. You'd probably get more and better answers posing this question in our S-Series Mods section.
Old 10-11-2006, 07:41 PM   #3
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
I think you mean a "colder" plug.
1996 SC1
RalliArt16 is offline   Reply With Quote
Old 10-11-2006, 09:08 PM   #4
scarecrow0529
1992 SC2
ur right colder
Old 10-11-2006, 09:49 PM   #5
eljefino
eljefino's Avatar
1995 SW1
If you can go colder without fouling then you've answered your own question.
The stock plug is a hotter compromise that lets the car start 20 times in 2 miles between the assembly line and dealer delivery prep.
Might be good to throw a good scantool on and see if you're presently getting any knock retard. If your tune is good and KR zero going colder won't help much.
Old 10-12-2006, 12:08 AM   #6
asdf
asdf is on a distinguished road
I think you usually want it fairly hot for better performance and economy. But if it is too hot and causes a lot of detonation, well, you know.
I about the only reason you would need to look for a colder plug would be if the compression was raised, but then you should also be using higher octane fuel. But I don't think this is your case.
Your best bet would indeed be investigating how much knock is going on currently.
asdf is offline   Reply With Quote
was wondering if i should run a hotter or colder plug 94503 S-Series Mods 1 02-23-2008 01:29 AM
Running Hotter than normal hilco5 L-Series General 7 07-30-2006 04:43 PM
Hotter heater... willfxp S-Series General 5 05-11-2006 11:57 PM
'99 SW2, running hotter, AC going south kailuamike S-Series Tech 5 04-28-2006 06:14 AM
Hotter Plug Applefool Mods and Performance 7 09-09-2003 03:42 AM
