Old 11-20-2005, 12:07 PM   #1
DHOOP
DHOOP is on a distinguished road
Default Motor Mounts
On a scale of 1-10, with 10 being the most miserable knuckle busting, how hard is it to replace lower engine mounts on a 96 SL2? I've done the upper and I figure that was about a 3.
DHOOP is offline   Reply With Quote
Old 11-20-2005, 04:32 PM   #2
Luke
Luke's Avatar
Default Re: Motor Mounts
three
Luke is offline   Reply With Quote
Old 11-20-2005, 04:41 PM   #3
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
I just did it on my SC2 96. Its not too hard. The only trick (if there is one) is that as the engine raises the torque mount wants to rotate it forward at the same time. This means that when you put the new one it, don't bolt it down. Set it down at an angle, cocked to the left so as you lower the engine, it will rotate to align with the new mount. Everything will look really cocked to the left (front of the car) but as you lower the engine everything rotates correctly and lines up (again, remember you are rotating against the torque mount).
Old 11-20-2005, 04:43 PM   #4
RobertGary1
BTW: I'm assuming you are talking about the foot mount under the tranny. If you are talking about the torque mount under the engine that is probably a 1. You may even be able to do it without raising the engine ( I did a bit but not sure it was necessary). The torque mount under the crank does not appear to be under any load what-so-ever when the engine is not torquing under load.
Motor mounts?? lubers S-Series General 15 04-27-2005 10:48 PM
My motor mounts? Turbosdime18 S-Series General 10 03-03-2005 08:26 PM
WTT: SPS Motor Mounts for Stock Motor Mounts soccer69er Classifieds 1 10-28-2004 07:13 PM
motor mounts 92saturnsl2 S-Series Tech 9 08-12-2002 01:08 AM
Motor Mounts Spanky Miscellaneous Tech 6 02-23-2002 07:00 PM
