Old 09-12-2005, 06:42 PM   #1
KBS_Caveman
KBS_Caveman is on a distinguished road
1997 SC1
Default The 92 dohc SL engine will fit the 97 sc1 right?
Title explains it all.
KBS_Caveman is offline   Reply With Quote
Old 09-12-2005, 08:25 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: The 92 dohc SL engine will fit the 97 sc1 right?
you'll have crank timing pickup issues if you keep the 97 computer/ignition module. And you'll need an adaptor to run the 97 egr valve, and troubles with the injectors too. And the fuel rail/pressure will be different. And the OBDII will complain, and if you rig the 92 computer you'll fail inspection if you have it.
Old 09-14-2005, 01:43 PM   #3
peterllo
peterllo is on a distinguished road
Eljfino sums it.
If you want to swap the motor, fine. You'll need to swap out the injector wiring harness for the donor car as well as the PCM. You'll likely need to swap the exhaust header, possibly the whole system as well, check it carefully. If you can salvage the exhaust you'll still have the second O2 sensor hanging there. Also bear in mind that motor after the swap may not conform to '97 emissions specs. If you have annual testing in your area that would become a major headache for you. I know I have a '94 DOHC in my '92 and am still trying to debugg the car.
I'd suggest getting a '97 motor. You'll still have to swap the harness with the computer but should be able to dodge the rest of the emission's issues.
PS don't purchase from 6th Planet.
peterllo is offline   Reply With Quote
Old 09-14-2005, 03:39 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
If you havent bought the engine yet, then dont. Get a 1993+ motor, considerably less headaches.
Old 09-14-2005, 07:21 PM   #5
KBS_Caveman
1997 SC1
Yeah i've done some research I will try to get a 93+ engine.
Also why not buy from 6th planet auto?
Swapped a 2001 SC1 DOHC engine with a 2000 SL2 DOHC now have transmission issues knukklhead S-Series Tech 18 04-13-2009 07:48 PM
Will an 1996 or newer DOhc engine fit in a 95 SC2(dohc)? e dogg S-Series Tech 4 04-05-2008 12:14 AM
Will a 1999 satrun sl 1.9L dohc engine fit in a 1996 saturn sc2 carmi987 S-Series Tech 8 02-24-2008 04:15 PM
Engine Swap will a sohc fit in place of a dohc 94SL Gyva S-Series Tech 7 01-31-2007 11:48 AM
WTB: Compatible Engine/ Transmission DOHC 97 Sc1 KBS_Caveman Classifieds 1 10-16-2005 11:28 PM
