Old 08-03-2005, 02:35 PM   #1
chicagomike
chicagomike is on a distinguished road
Default 1997 SC2 - 205K miles, need help changing/cleaning parts
I'm on the SW side of Chicago by Midway. Any advice where to go besides the dealer, or any mechanically inclined people local here?
I have a rough idle problem etc and not throwing codes. Long story short, here is what everyone is recommending to me here:
1. Clean or replace EGR valve.
2. Replace ETCS.
3. Replace Idle Control sensor.
I don't know where to get the parts cheap, and I need help installing / cleaning this stuff .. I found an EGR on e-bay for $40 used....
chicagomike is offline   Reply With Quote
Old 08-03-2005, 02:58 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: 1997 SC2 - 205K miles, need help changing/cleaning parts
First question, do you have the proper tools to do this job yourself? You'll need a ratchet, 10mm socket for the EGR, a 13mm for the ECTS, and I think the idle speed contol is held in by torx bits.
Pretty easy, remove the two bolts holding it in place and clean with carb cleaner. Getting a used one may yield the same problems you have now.
2. Replace ETCS.
Cant get much simpler. Wait till the engine is cold, unplug sensor, remove sensor, replace sensor, plug back in. Top off coolant.
Again, unplug, remove screws holding in place, install new sensor and plug harness back in. You'll have to remove the throttle body to do this. This requires a 10mm socket. With 205k miles, you should also replace the throttle body gasket.
I
In this situation, get stock sensors. They are not that expensive.
ECTS - $10.65:
http://www.trademotion.com/partlocat...97&catalogid=1
Idle Speed Control - $54.35:
EGR Valve - $127.76:
EGR Gasket - $4.42:
Old 08-03-2005, 03:00 PM   #3
SW1philly
SW1philly is on a distinguished road
SW1philly's Avatar
1994 SW1
As for locations of ECTS and EGR look at this thread closely.
http://www.saturnfans.com/forums/showthread.php?t=37884
In the 5th picture he has his hand right under the EGR valve.
SW1philly is offline   Reply With Quote
Old 08-03-2005, 04:25 PM   #4
chicagomike
I ordered all of the parts. The EGR looks easy! I will do that first. If no change, then the Idle control. Save the ECTS for last resort! It's possible I already have the brass one, I don't know for sure since Saturn replaced a lot of sensors in the past, but not the EGR or Idle ones.
I
ECTS - $10.65:
EGR Gasket - $4.42:
Old 08-03-2005, 05:52 PM   #5
chicagomike
FYI: SC Series - Emission system, Egr system, Valve gasket, VALVE GASKET, Saturn, All -
Discontinued
Old 08-03-2005, 09:52 PM   #6
eljefino
eljefino's Avatar
1995 SW1
Your new EGR valve should come with a gasket.
If you're just cleaning your old one, the old gasket shouldn't break if you're careful. It's foil on both sides and sticky on neither.
lookin at a 99 sl2 w/205K miles with excessive misfire juspay4speed S-Series Tech 21 03-06-2009 05:45 PM
where could i find parts for SC2 1997?? RockZ S-Series General 10 06-26-2007 02:27 PM
1997 Saturn SC2 - 114K miles, needs work - $1500 obo rdefabri Classifieds 13 06-21-2006 03:46 PM
Need Body parts for 1997 SC2 bluemalibu79 Classifieds 1 05-01-2006 09:09 PM
For Sale: 1997 SC2 less than 50k miles Horror Show Classifieds 1 04-19-2003 11:29 AM
