Old 09-17-2004, 08:13 PM   #1
andybot2000
andybot2000 is on a distinguished road
Default Whining noise from power steering pump/reservior
A couple weeks ago, I began to notice a strange whining sound from the engine of my 96 SL2. It makes the noise whether the car is in gear or not, so I know it's not the tranny. The whining sound increases and decreases in pitch according to the engine RPM. I checked under the hood, and it sounds like the noise is coming from the power steering pump or reservior. The fluid is full, very clean, no leaks. Is this just normal aging, or is something funky going on? I'm thinking maybe the pulley is just getting louder with age?
andybot2000 is offline
Old 09-17-2004, 08:45 PM   #2
Default
Are you sure that it is from the PS? An alternator with bad diodes will make a high pitched whine that varies with the RPM. The alt is directly below the PS pump.
ssicarman is offline
Old 09-18-2004, 02:25 PM   #3
Lucas1
Lucas1 is on a distinguished road
Default
like ssicarman said, check the alternator. but if the sound does turn out to be from the PS pump ( ive seen a few of them make this type of noise before) then try this. add about 1 tablespoon of STP oil treatment to the resivor and turn the wheel back and forth about 10 times although it may take a few days to totally go away, it should help the noise, if it doesnt then a new pump is the only thing that will fix the noise. a guy i used to work with showed me that trick, he used to work at a ford dealer, ford is notorious for power steering noise, he said they would keep cases of that stuff around to quiet the ps pumps.
Lucas1 is offline
Old 09-18-2004, 05:58 PM   #4
JPDucketts
JPDucketts is on a distinguished road
Default
are you sure it's the pump and not the idler pulley? thats the one in the center of the front cover under the top mount. it sounds similar. does the noise change when you turn the wheels? if not, it could be the idler. carefully place a long screw driver on the center bolt of that pulley while the engine is running and put your ear on the screwdriver. you may hear the noise there. if not, try placing it on the back of the pump and listening there. that may narrow it down for you.
JPDucketts is offline
Old 09-27-2004, 04:36 PM   #5
andybot2000
Default
The noise must have been coming from the alternator, because the battery light came on and now she won't start. The battery is only 3 months old. I'm going to attempt to replace the alternator today using wolfman's awesome how-to.
Thanks everyone for your input. I love this site.
Power steering pump noise on cold start. Wolfc70 L-Series Tech 2 01-15-2009 03:38 PM
Power Steering Pump and Alternator Problems - Whining noise and Burning Smell batmobile S-Series Tech 14 08-03-2006 12:29 PM
Need quick help - replacing power steering pump and water pump on V6Ö. Emanresu2 L-Series General 6 05-18-2006 05:38 PM
where is the power steering reservior sellhammer Ion General 22 02-05-2006 10:02 PM
Power Steering Pump? sc2_94 S-Series Tech 7 10-27-2001 12:05 PM
