Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 03-24-2004, 05:35 PM   #1
hummers86
hummers86 is on a distinguished road
Default Turbo Cost
Whats usual price for a t3 turbo only? How much like on ebay? And how about used at a junkyard? What would be a good price and what would be too much? Thanx sorry if someones already asked this.
hummers86 is offline
Old 03-24-2004, 06:24 PM   #2
TheSaturnKid
TheSaturnKid is on a distinguished road
TheSaturnKid's Avatar
Default
350 on ebay for a rebuilt one.
New they can run from 600-1000 for a NEW T3.
Junkyard is anyones guess. Probably 10-100 depending on condition and the owner of the yard...
TheSaturnKid is offline
Old 03-24-2004, 07:00 PM   #3
ProDarwin
ProDarwin is on a distinguished road
Default
$5 to $1000 depending where you find it.
-Travis
ProDarwin is offline
Old 03-24-2004, 08:16 PM   #4
Tycho
Tycho is on a distinguished road
Tycho's Avatar
Default
Get a Borg Warner GM5 (T4 equivalent) from a Chevy 6.5 diesel.
I have 3 of em in my collection from ebay...they run about 120 apiece.
Forced induction is rape.
Tycho is offline
Old 03-25-2004, 12:19 AM   #5
hummers86
Default
im just lookin for a little boost like 5psi. How much hp you suppose that give me?
Old 03-25-2004, 01:21 AM   #6
TheSaturnKid
Default
160-200 depending on the turbo you use.
Old 03-25-2004, 01:31 AM   #7
hummers86
Default
What you think would be good to do for the fuel managment? Im poor so Im not gettin a stand alone. i was thinkin like on turbosaturns.com do the bigger injectors with fuel regulator or the Apexi if i can get it cheap Thnx
Old 03-25-2004, 03:46 AM   #8
Tuanies
Tuanies is on a distinguished road
Default
Which cars came with the T3 from factory? Local wrecking yard sells any turbo for $16.50.
Tuanies is offline
Old 03-25-2004, 03:59 AM   #9
Bigbadbert
Bigbadbert is on a distinguished road
Bigbadbert's Avatar
Default
I dont think 5 psi would give you 160-200 hp with a T3, probably more like 50-70 depending on tuning and your exhaust.
'01 SC2 - sold
Bigbadbert is offline
Old 03-25-2004, 04:42 AM   #10
Tycho
Tycho's Avatar
Default
Buick Grand National turbos can be had cheap...
The borg warners are in such good shape tho...and will push 15 PSI no sweat...you know you want one...
Tycho is offline
Old 03-25-2004, 02:08 PM   #11
TheSaturnKid
Default
Some people have used that, but with low boost.
The two biggies that people have used with much success at low and high boost are the SDS EIC and the megasquirt.
The sds is a supplemental fuel injector that squirts fuel into your intake charge.
The megasquirt is a fuel computer thats relatively inexpensive.
www.turbosaturns.net the guys there know their stuff and can help you a lot more effectively than most people here.
Old 03-25-2004, 04:02 PM   #12
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default
5 psi will give you about a 25-30% HP gain. 15 psi will almost double HP.
Turbo Calculator
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
lostwages_ls2 is offline
Old 03-25-2004, 06:27 PM   #13
hummers86
Default
Thanx for the info, im curious tho, im poor and just want some more power whats the max psi i could go without havin to change to much stuff, fuel regulation, etc. ? like 7psi? Thanx
Old 03-25-2004, 06:37 PM   #14
TheSaturnKid
Default
You need more fuel at 1 psi let alone 7.
Old 03-25-2004, 07:32 PM   #15
hummers86
Default
Yea but i just dont want this thing to be anything major like a stand alone or sumthin
Old 03-25-2004, 08:09 PM   #16
lostwages_ls2
Default
Most setups should be able to compensate at 5psi boost. Higher boost could require more fuel than either the computer is set up for or could exceed the capacity of the injectors. With higher boost comes the possibility of detonation. You would also need to run higher octane fuel and possibly need a different spark plug heat range.
Obey the Min Pin
Old 03-26-2004, 12:15 AM   #17
TheSaturnKid
Default
What do you mean by most setups? The saturn pcm cant even read boost.
The dumb obd1 may be able to compensate for small boost with just bigger injectors...
But obd2 will not.
For high boost yes you need to retard timing a few degrees, up to even 6 or more...
You will need colder spark plugs too.
If you arent going for high boost then just get the sds eic. Its cheap and effective.
But you will be surprised how much money you will spend just for a low boost setup. 2Gs or more... And once you feel the boost I bet you wont be able to stop yourself form turning it up... You lean on the stock engine and boom!
Old 03-26-2004, 02:51 AM   #18
Bigbadbert
Bigbadbert's Avatar
Default
SCDYNE and SIYAM know alot of good stuff about boosting first hand. www.qksltwo.com is a good site as well.
'01 SC2 - sold
Old 03-26-2004, 03:45 AM   #19
JoshuaTree
JoshuaTree is on a distinguished road
JoshuaTree's Avatar
Default Which yard only charges $16.50?
JoshuaTree is offline
Old 03-26-2004, 04:29 PM   #20
TheSaturnKid
Default
I meant total power.
possible low cost turbo/supercharger digiforce S-Series Mods 16 06-08-2008 12:09 PM
would it be more worth it to buy a different car to turbo or should i turbo my 98 sc2 saturnguy125 S-Series Mods 24 05-23-2008 10:31 PM
FS: Turbo Exhaust Manifold with Saab Turbo amazinghl Classifieds 1 07-14-2004 07:54 PM
how much did your turbo setup cost? brentg Mods and Performance 4 10-20-2003 03:16 PM
For sale SOHC turbo manifold, downpipe, & T25 turbo turbo98sc1 Classifieds 0 08-27-2003 01:05 PM
