Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 01-23-2004, 12:38 PM   #1
elvinrodr
elvinrodr is on a distinguished road
2008 VUE 3.6L
Question 99 block with 92 head
Is it possible to put an early MY cylinder head on a 99 block?
elvinrodr is offline
Old 01-23-2004, 01:19 PM   #2
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
Default
Gotta use a 92 computer. And everything that connects to the head has to be 92-spec as well.
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
bennett9000 is offline
Old 01-23-2004, 06:16 PM   #3
planet6racing
planet6racing is on a distinguished road
planet6racing's Avatar
1992 SL2
1992 SL2
Default
Do not use a 91-92 computer with a 99 block. The notch the CPS uses is in a different spot (roughly 30 different). Check for compatibility between a 93-95 PCM and the 99 crank.
Bill
Planet 6 Racing
SCCA ITA #92
planet6racing is offline
Old 01-23-2004, 10:10 PM   #4
SIYAM
SIYAM is on a distinguished road
Default
10 degrees off.
Ian
http://www.qksltwo.com
SIYAM is offline
Old 01-23-2004, 10:55 PM   #5
wolfman
wolfman's Avatar
Default Re: 99 block with 92 head
YES. If the car is a 99' (using a 99' PCM) and the head is ANY year prior but not after 99', the ONLY issue will be fuel rail and EGR mounting. The fuel rail can be relatively easily adapted to work and there IS an adapter plate (a 94' part) that will allow a newer (99') EGR valve to mount to an older head. You will have an extra coolant temperature sensor in an earlier head used on an OBD2 (96' and up) car. It can just be left unconnected with no issues.
wolfman is offline
Old 01-28-2004, 05:10 PM   #6
CrucialSaturn
CrucialSaturn is on a distinguished road
CrucialSaturn's Avatar
Default
what kind of compression change would you have?(if any)or is it cause you want the 92 factory header to mount?
CrucialSaturn is offline
Old 01-28-2004, 09:56 PM   #7
wolfman
wolfman's Avatar
Default
A 92' header WILL mount to a 94' head but NOT to a 00' or UP head..A 94' head on a 99' block will yield normal factory compression ratios. Cylinderheads changed in 00' IF your car has a PLASTIC intake manifold and VERTICALLY mounted throttle body you have the "new" style (00' and up) head. (junk)
wolfman is offline
head/block before/after should i resurface 93SC2'in S-Series Tech 11 11-15-2008 11:03 PM
'96 head on '99 block? cuff S-Series Tech 5 08-05-2008 01:08 PM
98 model head and intake on 01 block.. a88ruby S-Series Tech 3 02-26-2008 06:21 PM
92-93 block 97 head? netsniper S-Series Tech 9 05-15-2007 01:13 PM
can you put a 2.4 block on a 2.2 head jhutch2115 Ion General 3 07-28-2005 02:50 AM
