Old 05-05-2011, 09:29 AM   #1
Nitroracer
Nitroracer is on a distinguished road
Nitroracer's Avatar
2002 SL
Default Rear Door Latch Problem
The drivers side rear door on my 02' SL has been a little stiff to open so I went to look at the latch today and see if I could find the problem - unfortunately I created a new one.
I tripped the cam inside the door portion of the lock and now I can't reset it, as if the door was stuck shut to the car. I need to pull toward the interior with the door handle pulled up correct?
Nitroracer is offline   Reply With Quote
Old 05-05-2011, 11:20 AM   #2
Default Re: Rear Door Latch Problem
Yeah, stick a screwdriver shank into the latch to "emulate" the striker. Push inboard on it (same as outboard force opening the door) while pulling the inner or outer handle. Latch should release.
Old 10-01-2011, 11:37 PM   #3
sam7474
sam7474 is on a distinguished road
sam7474's Avatar
Hey Nitroracer,
Any luck with that door stiffness in the door handle? Curious thing, my rear driver's side one suddenly got stiff within a matter of a week or so too. When you pull the door handle to open the door, it doesn't spring back into place. I'm wondering if it's simply corrosion.
What did you do to solve the problem? I'm fishing around for a few answers before trying to take the door apart.
Thanks,
Sam
sam7474 is offline   Reply With Quote
rear door latch nydriver S-Series Tech 1 04-19-2011 09:29 AM
adjusting rear door latch to lock red92xblue S-Series Tech 2 11-10-2009 01:32 PM
Door Latch problem Kevin_C5 Vue General 2 04-04-2009 06:16 PM
Rear Door Latch andyr13 Vue General 5 07-17-2008 09:17 PM
Rear driver door latch 97 SL2 mainedvd S-Series Tech 4 12-31-2007 05:17 AM
