Old 08-17-2009, 08:33 AM   #1
bdobraj
bdobraj is on a distinguished road
1993 SC2
Default oil consumption/burn
i noticed that my car burns oil like all s-series, im not positive but i would say about 1/2 quart for 650 miles or so. anyway, i hear that doing a pisition soak or something like that will reduce the oil burning? any details on that?
bdobraj is offline   Reply With Quote
Old 08-17-2009, 08:51 AM   #2
Baron5867
Baron5867 is just really niceBaron5867 is just really niceBaron5867 is just really niceBaron5867 is just really nice
1994 SC1
Default Re: oil consumption/burn
Search function is your friend.
Baron5867 is offline   Reply With Quote
Old 08-17-2009, 05:10 PM   #3
Tiger
Tiger's Avatar
Here is one:
http://www.saturnfans.com/forums/showthread.php?t=80118
Wolfman also has a nice write up in the How-To library.
Old 08-17-2009, 07:51 PM   #4
Pitcher
Pitcher's Avatar
Yes, the search is great.
I have to search for front coil replacement - just found out my front spring is broken on my 1st ever Saturn I just bought last week!
Old 08-18-2009, 08:16 AM   #5
bdobraj
1993 SC2
alright, i did Wolfmans procedure for the MMO piston soak, except i didnt get any white smoke on start up like wolfman said would happen, also he said you might find difficulty starting up but my car went right up. did i do something wrong?
Old 08-18-2009, 08:47 AM   #6
Kinda hard to tell... since we weren't watching you
It might help if you told us what you actually did. However, the best way to test what happened is just to drive through a normal tank of gas or two and check your oil consumption every couple of hundred miles.
If your soak didn't work, as an alternative to the MMO soak - search for a post by cboss with 'seafoam' in it. He mixed some kind of oil (CDC?) with Seafoam to get a certain conistency (50/50, IIRC) and did the piston soak... seemed to have helped him.
Old 08-18-2009, 09:38 AM   #7
rlhdghhmh
rlhdghhmh is on a distinguished road
rlhdghhmh's Avatar
2002 SL1
I checked tigers page and seen the pics and instructions but can anyone tell me if the filter will work for the SOHC or is there a different size in the same brand.
2002 SL1 GO BIG OR GO HOME
rlhdghhmh is offline   Reply With Quote
Old 08-18-2009, 09:56 AM   #8
DonP
A quart every 1300 miles is not too bad. You might consider a couple AutoRx treatment cycles as well. It provides gradual, gentle, cleaning and might help consumption.
Old 08-18-2009, 01:26 PM   #9
Did you happen to peer into the chamber to see if there was any MMO left on the piston tops? It's possible that most of it leaked down into the crankcase, and you managed to expel the rest before starting it, meaning minimal/no smoke. I've read here that it's actually a _good_ sign if the MMO drains down, that means it's unlikely there's consumption-causing buildup on the oil rings.
Old 08-18-2009, 03:27 PM   #10
Tiger
Tiger's Avatar
Yes, the filter will work. Motorcraft FL-400S is just an oversized filter. I have been using oversized filters for years. For example, I bought Adavance Auto Total grip filters. They are AA3600 for oversized. Saturns use a AA3614 according to a reference. Same with SuperTech at Walmart. A ST3600 is oversized. ST3614 is the one they list for a S-Series. It gives you more filter area and you can load it up with more crud before going into the bypass mode. As long as the bypass pressure is correct, and the diameter is correct, the size does not matter (unless there is no space for length). More examples of oversized filters are Wix 51516, Mobil 1 M1-209, and Purolator PureOne PL20195. The last 3 were high quality with better filtration. The Mobil 1 filter is very expensive. The Motorcraft FL-400S is comparable to the Purolator PureOne. It is a good bang for the buck quality overized filter. The neat thing is I can use any one of these filters on my parents Briggs and Stratton motor on their rider. A briggs filter is over $12.00, so I saved $9 installing a SuperTech ST3614.
Old 08-19-2009, 08:28 PM   #11
bdobraj
1993 SC2
well, i let the car sit overnight when i did it, and when i cranked it over in the morning, i saw the rags fly out, but no spitting MMO... if that was supposed to happen... i put about 5 oz in the gas tank as well. i had filled about 15-20 miles prior so i figured there was no harm.
Old 08-19-2009, 10:22 PM   #12
No. You're only supposed to use one rag, draped over all four holes. If you stuff anything into the holes, the air pushed up by the piston will just blow it out like a pop-gun cork. The idea is to have a single rag, heavy enough to stay in place when the MMO comes flying out, _draped_ across all four holes.
But if you don't have a mess of MMO on your hood pad, or the front end, or the engine compartment, and there was no smoke, it certainly sounds like it all drained into the crankcase.
Old 08-20-2009, 07:00 AM   #13
bdobraj
1993 SC2
alright well then i will take it as a good sign then lol.
Are SL2's known to burn oil? dpstang98gt S-Series General 33 11-26-2008 12:22 PM
Why do I burn Oil so fast??? savedbygrace S-Series Tech 14 04-27-2008 12:25 AM
Changing oil burn? Admiral Beez S-Series General 2 12-15-2005 03:11 PM
Oil Burn? saturn4 General Saturn Discussion 5 06-21-2001 06:07 PM
How much oil do you burn? MrBigglesworth General Saturn Discussion 26 07-28-2000 06:31 PM
