Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay Tech
Old 05-27-2008, 06:50 PM   #1
seadub2
seadub2 is on a distinguished road
Default Service Anti Theft system
Got this indication on the DIC of my 2005 Relay, accompanied by the steady red light on the speedo:
"Service Anti Theft System"
The system still sets with the key fob, the horn chirps and the resident red LEDs on the dash and radio blink.
All else is normal.
Has anyone had this, and if so, what was the cause and fix?
Thanx...
C.W.
seadub2 is offline   Reply With Quote
Old 05-28-2008, 08:04 AM   #2
Default Re: Service Anti Theft system
Have you tried referring to your owner's manual for information? There may be a little more info in your manual before troubleshooting the problem. Some of the problems may be; BCM related like the Passlock sensor in the ignition switch, the BCM, possible re-synching needed between the keyfobs and the BCM, etc..
Old 05-28-2008, 08:46 AM   #3
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
try using a different key. maybe something goofy with the key immobilizor
Old 05-30-2008, 07:30 PM   #4
seadub2
I checked the manual; nothing except very generic info. No fuse labled security system or anything like it.
Question - What's a BCM?
C.W.
Old 05-30-2008, 07:39 PM   #5
Some of our more sophisticated models like yours, mine, Ions, Vues, have more than one computer that isn't managing the engine. The body control module (BCM) is one of them that handles cruise control, coordinates the diagnostic troubles among the computers, Passlock vehicle anti-theft system, headlights, brake lights, DRL's, instrument lighting, etc.. The anti-theft system is part of the BCM and remote key functions/synching.
Old 05-31-2008, 09:06 AM   #6
seadub2
Thanks for that....BTW my wife's key provides the same message.
I did some research and it appears the GM BCM contains a battery backup to hold the passkey and fob data in the event the main vehicle battery poops out; something like the lithium battery on a motherboard that retains the user settings in the CMOS. This makes sense given that the system still appears to work normally, i.e., the little LED on the dash flashes and the one on the radio also flashes once the system is armed, and the horn toots as it should. This is the case whether arming the system by the fob or by pre-locking with the power door lock button upon exiting the vehicle.
Does this sound plausible? If so, where is the BCM located, and what exactly am I looking at as far as modules, dashboard, etc. necessary to remove to replace the battery?
Thanks again for your help and input.
C.W.
Old 07-31-2008, 03:57 PM   #7
seadub2
Problem found - the code, "Transponder Modulation - No Modulation" was caused by a passive door security fob on our key chains used to open the door at our kid's day care. Apparently when the ignition key reader sent its request to the PassKey, the door fob also responded, confusing the BCM and setting the code.
We moved the door fobs to the other end of our key chains. Code disappeared, problem solved.
C.W.
Old 07-31-2008, 04:35 PM   #8
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
i have actually heard where you need to be careful what is on your keychain. even with more than one key so close to the transponder reader the car can pick up 2 dsifferent signals when it decides if it wants the car to start.
Old 08-15-2008, 08:17 PM   #9
Evan
Evan is on a distinguished road
My mother's Relay flashed the same message today about the theft system needing serviced. She did have the access key for her gym on it so I removed it and the message still remains with both keys. Are there any other possibilities or should I wait a little while longer to see if it clears itself? All the functions are still working fine.
Evan is offline   Reply With Quote
Old 08-16-2008, 07:28 AM   #10
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
id at least try a different key, maybe it doesnt like that immobilizer key.
Old 08-16-2008, 08:51 AM   #11
Evan
Well I went back out later and the message was cleared and no light came on so maybe it was the key card.
Old 05-24-2009, 12:43 AM   #12
jbracefan1977
jbracefan1977 is on a distinguished road
Ive been trying to figure out this problem. thanks for post.
jbracefan1977 is offline   Reply With Quote
anti theft system jsmith2585 L-Series Tech 3 10-08-2009 12:17 PM
What is Protection Plus - Anti-Theft? Brak Aura General 7 06-15-2009 12:28 AM
Help With Radio Anti Theft System rogdevchan S-Series Tech 3 08-12-2008 05:26 PM
Anti theft system problems 2006 Vue Squid4395 Vue General 16 04-13-2006 09:09 AM
anti-theft drewsl2 General Saturn Discussion 5 10-05-2001 03:15 AM
