Old 12-20-2007, 05:28 PM   #1
goldmember
goldmember is on a distinguished road
1998 SW2
Default Rear wiper nozzle won't spray
Hi All,
I have a 98 SW and the rear wiper nozzle has stopped spraying. There's fluid in the tank. When I turn the switch to pump fluid, I'm don't hear anything. So either the pump is dead, or there's an electrical problem b/w the pump and the switch. I don't see a fuse just for the rear pump, so I'm guessing it's combined with other items on the rear harness. I've checked the nozzle itself and no clogs, leaks, etc. anywhere.
The rear wiper works fine, it's just the nozzle won't spray. Any ideas would be helpful. Also where would I look for the rear pump (side panel where the tank is located?) to troubleshoot.
Thanks in advance...
DJ
goldmember is offline   Reply With Quote
Old 12-20-2007, 06:04 PM   #2
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: Rear wiper nozzle won't spray
Check the sun fuse first.
Old 12-20-2007, 09:22 PM   #3
goldmember
1998 SW2
Thanks for the reply! The sun fuse checks out okay. Any other thoughts?
Old 12-20-2007, 10:12 PM   #4
richpin06
richpin06's Avatar
Check the dark green wire at the switch.It could have broken off from the solder joint.It has been known to happen.
Old 12-20-2007, 11:49 PM   #5
mbr
mbr will become famous soon enough
1998 SW2
That's what happened to mine.
Take the top cover off the steering column. The wires coming from the stalk go to a terminal. The flexing of the wires when using the wiper stalk broke the wire at the terminal. Soldered it back with a little extra wire.
mbr is offline   Reply With Quote
Old 12-21-2007, 12:54 AM   #6
Happened to me, too. I ended up replacing the whole multifunction switch, and shipping my old one to an SF member with a sedan, before I realized that this was probably all that was wrong with mine.
Old 12-21-2007, 11:16 AM   #7
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
With me its the opposite, my washer works but the wiper doesnt.
OU812 is offline   Reply With Quote
Old 12-21-2007, 01:23 PM   #8
Well, in fact, that happened to my with the replacement multifunction switch. Not wanting to go thru that R&I adventure again, I explored and found the very thing richpin mentioned, but with the wiper wire (d'oh, I forget the color). IIRC, I just "sistered" in a piece of wire right from the harness; I figure if there's a time in the future I need to remove the wheel for anything else, I'll get in there an do it up right.
Old 12-21-2007, 04:38 PM   #9
goldmember
1998 SW2
That was it! I resoldered the joint and it's working again. Thanks guys
Rear Washerfluid Nozzle willfxp S-Series General 8 02-27-2014 02:07 PM
Rear Window Spray Nozzle - dribble or spray? mellissam Vue General 10 12-05-2006 12:51 PM
Windshield Wiper Spray Nozzle.... eternalstdnt S-Series General 7 02-06-2005 05:18 PM
Windshield Spray Nozzle petemcs Miscellaneous Tech 3 02-08-2004 11:07 PM
Rear washer - no spray Isophorone S-Series General 7 02-04-2004 06:38 PM
