Old 11-21-2007, 01:19 PM   #1
Cessna
Cessna is on a distinguished road
1997 SW2
Question Front suspension noise/rattle over bumps passenger side
I'm having trouble with suspension noise on the passenger side going over bumps. Here is a list of what I have done so far:
Replaced front upper and dog bone mount, loosened and reset lower mounts
New wheel bearings and lower control arms (SKF and Moog) <15000 miles ago
Replacing the motor mounts made a HUGE improvement, but there is still a rattle when going over bumps. I think the strut bearing plate is causing the problem. The driver side sounds fine. Just looking to see if anyone else thinks this could be it. Is there a way to test the bearing plate in the car? I might just have to get the tools and remove it to check the brearing.
Thanks to all.
Cessna is offline   Reply With Quote
Old 11-21-2007, 03:14 PM   #2
Default Re: Front suspension noise/rattle over bumps passenger side
Bounce the bumper while you have the hood open, and observe the strut mount plates. When mine went bad, you could actually see the gaps change as you bounce the car.
Noise from front passenger side wheel pimpin88 Vue Tech 2 08-23-2009 08:48 PM
Noise in the right front passenger side (Third time) dbunch Vue Tech 2 01-14-2008 10:58 AM
passenger side clunking over small bumps davemac2 S-Series Tech 5 12-31-2007 09:41 PM
Solution Found:!!!! for Passenger Side Windshield Wind Noise/Rattle dtm1962 Ion General 3 10-04-2005 07:38 AM
L300 Front Passenger Side Rattle AArmstrong L-Series General 7 10-17-2004 06:41 PM
