Old 04-11-2006, 12:07 AM   #1
Smiley1
Smiley1 is on a distinguished road
Default Just got a 96 SL2. Have questions.
Well I did it. I bought the 96 Saturn SL2 for 2k. Just need to do the 100k mile tune up.
Thanks to everyone that replied to that thread. It was a big help.
Could you folks help me out on what I should be replacing?
PCV
Plugs (are NGK the best for this motor?)
oil (what weight?)
Trans Gear oil? (what weight and specs?)
plug wires
What else? I dont have a owners manuel. What else needs to be done?
I also have 195 65 15's on it now. They need to be replaced but I dont know if these are stock or not. Tirerack shows a 185 65 15. Im confused.
I have done some searching and continue but its a very slow process.
Thanks,
Rob
Smiley1 is offline   Reply With Quote
Old 04-11-2006, 12:44 AM   #2
madpogue
1996 SW2
Default Re: Just got a 96 SL2. Have questions.
Originally Posted by Smiley1
PCV
oil (what weight?)
plug wires
PCV - OEM
Plugs - lots of opinions, but for sure, NO platinums
Oil - subject of entire holy wars
Trans - manual, I presume? It actually takes ATF. Mobil 1 ATF will make it smooth, like buttah!
Plug wires - at the very least, stay away from Wells (they're cr@p)
Get an owner's manual via eBay.
If the ECTS (Engine Coolant Temp Sensor) is original, replace it. Search our How-To on "ECTS" for the whole story.
Cleaning your EGR, throttle body and IAC (idle air control, in the TB) is always helpful
Old 04-11-2006, 12:47 AM   #3
DukeCitySC2
DukeCitySC2 is on a distinguished road
DukeCitySC2's Avatar
2006 ION-2 Sedan
1993 SC2
Engine oil weight (for Spring weather) -- 10w30
trans oil -- Dexron II ATF (assume this is a manual trans?)
Check your engine mounts
Check the ECTS for leakage
Might want to run some SeaFoam in the oil before changing, for maybe 50-100 miles.
(edit) dang - beat me to it!
DukeCitySC2 is offline   Reply With Quote
Old 04-11-2006, 09:21 AM   #4
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
195-60-15 will do. The 65s are a bit tall.
eljefino is offline   Reply With Quote
Old 04-11-2006, 09:28 AM   #5
sven1
sven1 is on a distinguished road
sven1's Avatar
2001 L-Series 2.2L Sedan
Don't forget the air filter. Commonly forgotten and can make a huge difference.
sven1 is offline   Reply With Quote
Old 04-13-2006, 12:21 AM   #6
Smiley1
I replaced the following:
-Oil (Mix of 1:1 of Motorcraft 5-20w and Delo 15-40w)
-AC delco oil filter
-STP air filter
-Fuel filter
-Plug wires
-AC Delco Plugs
-PCV
-Tires (BFG touring in 185 65 15)
-Alignment
-Mobil-1 ATF
-ECTS (waiting to be put in)
-Sea Foam treatment through the intake (neighbors were yelling at me, "What did you do to your car??")
-Throttle body cleaned
-Techron treatment in the gas
What am I missing anything?
I start my first 120 mile commute tomorrow. Im hoping for 30+ MPG. Thanks for all the help!
BTW, how many gallons are our gas tanks rated at?
Old 04-13-2006, 01:20 AM   #7
scsomike
scsomike is on a distinguished road
the owner's manual says 12.2 gallons.
'97 SL2, 5spd get around car.
scsomike is offline   Reply With Quote
Old 04-13-2006, 11:38 PM   #8
Smiley1
I went on my commute and got 37 mpg on California crap gas!! This is with the cruise set at 71-72 mph. I am very happy!
Old 04-20-2006, 11:14 PM   #9
Smiley1
I calculated the MPG for the tank at 35 MPG exactly. Its mostly highway with a little city driving. Is this the average?
I sure like this car. Its saving me a ton of money. Gas just went up to 3.15 for regular. This car will pay for itself in a shorter time than I thought.
I just got some German Castrol 0w30 for a cleaning phase. The car had 2k miles on the oil, but it was over a year since it was changed. I have a mix of Delo 15w40 and Motorcraft 5w20 right now as a rinse.
Old 04-20-2006, 11:53 PM   #10
mudnsoccerguy
mudnsoccerguy is on a distinguished road
1996 SL2
You may also want to do a coolant flush. I did one on the 96 sl2 that I bought last fall and the previous owner had been mixing antifreeze and dexcool.
1996 Saturn SL2 90k miles, 3rd owner
mudnsoccerguy is offline   Reply With Quote
Old 04-21-2006, 01:13 AM   #11
Smiley1
LOL. Thats not good. I noticed after I bought mine that someone had just replaced the radiator as its brand new as well as the green coolant. Good advice though as I planned on it until I inspected it.
Mud, What oil and weight are you running in yours?
Old 04-21-2006, 09:44 AM   #12
mudnsoccerguy
1996 SL2
I'm running the 5w30 Jiffy Lube special. Yes I know that the consensus is that these aren't always the most reliable places, but they do offer free top offs and I'm burning/losing 1 quarter every 2 gas fill ups. I'll get around to tracking down the bad gaskets and doing the MMO soak this summer, but for now it's the easiest and cheapest way to handle the problem.
Questions Questions MPG 93 SL2 Labradoofis S-Series Tech 3 09-13-2009 01:01 AM
95 sl2 questions Scott Peterson S-Series Tech 25 01-21-2009 03:58 AM
3 questions '95 SL2 hmundyiii S-Series General 0 07-11-2007 12:15 PM
92 SL2 Questions frenchy396 S-Series General 5 07-06-2005 08:49 PM
92 SL2 Questions Aldiaz2331 S-Series General 9 07-29-2004 02:48 PM
