Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 05-13-2004, 01:55 AM   #1
JoshuaTree
JoshuaTree is on a distinguished road
JoshuaTree's Avatar
Default Problem with my springs
I lowered my 02 Sl2 a couple weeks ago with intrax springs. I kept hearing this rattling noise like a spring wasn't sitting on the perch right or the nut around the strut shaft wasn't tight. It boggled my mind. I never had a problem with any noises, not even when I bought cheapy coilovers for my civic.
Every time I inspected the setup, it was while the car was on the lift. So I decided to look at the spring while they were compressed. Found that the coils were really close to each other.
Upon further inspection. I found that the coils have been smacking each other(powder coat was flaking off). I put rubber hose between the coils(only a couple coils on the bottom). Guess what no more rattle.
Any ideas? Bad design?
JoshuaTree is offline
Old 05-13-2004, 02:56 AM   #2
splat
splat is on a distinguished road
Default
Hey einstein, you don't have to post in every section you see...most of us will migrate over to the s-series section when we're done...with that said, you weren't the first to think of it, if you search, you'll notice that it's common, and alot of people have done this before...everything from water hose type deals to wire loom...it's not a design flaw. they all do that...
splat is offline
Old 05-13-2004, 09:01 AM   #3
eRic 02sc2
eRic 02sc2's Avatar
Default
you can use some split wire loom from radio shack and slide it over the bottom coils on the rear springs. the issue is that the lowering springs are shorter (duh) than stock so they tend to bounce off the stock spring perches when the rear suspension is fully extended. a saturn is not a civic.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 05-13-2004, 11:48 AM   #4
JoshuaTree
JoshuaTree's Avatar
Default Thanks for being so nice
It has to be a design flaw. I've lowered many cars. using all types of springs. never had any problems. If the spring is installed correctly and it never stops rattling, that is a flaw.
Old 05-13-2004, 12:14 PM   #5
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
I wouldn't consider it to be a flaw. The stock springs don't rattle like that -
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Applefool is offline
Old 05-13-2004, 03:07 PM   #6
splat
Default
A flaw is something they didn't plan on...
in this case, in order to give the best ride, handling, and such they had to compromise...
thus it's not a flaw..
splat is offline
Old 05-14-2004, 01:57 AM   #7
JoshuaTree
JoshuaTree's Avatar
Default
Ok it's not a flaw. It's just bad design. I like that part "best ride" If it rattles how can it be the best ride?
Old 05-15-2004, 01:27 PM   #8
eRic 02sc2
eRic 02sc2's Avatar
Default
stock springs don't rattle becuase they are longer and take up the space provided by stock struts. when you install shorter springs you have extra play in the springs when the rear suspension is fully extended. only the rears have this issue. the fronts are under tension so they don't rattle. it's not a flaw. it's not bad design. that's just how it is. say you have 8 inches of rear strut travel and the stock springs free length are 8 inches so they take up the alloted space. now replace the spring with one that's got a free length of 7 inches. you still have 8 inches of travel but only 7 inches of spring in that space which lowers your car by 1 inch. at some point when you extend past 7 inches to the 8 inches max, your spring is free to bounce off the spring perch and you'll hear a clanking sound from the rear.
eRic 02sc2
WTT H&R Supersport Springs for Stock Springs DOHC Brown Classifieds 10 09-27-2006 06:41 PM
Lowering Springs Problem...Eibach Barry Ion General 5 07-06-2004 11:59 PM
Problem with my springs JoshuaTree S-Series General 2 05-13-2004 12:46 PM
97 sc2 springs different from 97sl1 springs??? Rear-Vue General Saturn Discussion 1 11-18-2003 09:35 PM
springs mr.martin003 Mods and Performance 3 03-20-2003 11:58 AM
