Old 09-25-2019, 02:50 PM   #1
TwoFistedJustic
TwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the rough
Default What are the little plastic doohickeys that hold the electrical connectors to the bra
I'm replacing my vapor canister purge solenoid because I have the starter off anyway and this job is about 500 times easier with the starter removed. And the part is cheap.
What are the little plastic doohickeys that hold the electrical connectors to the bracket called? And does anyone know where to get more?
TwoFistedJustic is offline   Reply With Quote
Old 09-25-2019, 05:54 PM   #2
bluesl2
bluesl2's Avatar
Default Re: What are the little plastic doohickeys that hold the electrical connectors to the
I believe they might be called rosebud clips.
Old 09-25-2019, 07:21 PM   #3
TwoFistedJustic
Close but no cigar. Rosebud clips clip around the cable.
Found something similar called a Self Leveling Sensor Wire Clip
ACDelco 12084149
it might work, kind of pricey...
$7+ from Amazon, about $4 from Rockauto
Ordered one from Amazon. Will see if it fits. If not, return.
Old 09-25-2019, 11:57 PM   #4
TwoFistedJustic
I figured out how to remove the old clips so that they are reusable!
I used Sil Glyde as a lubricant, then with bent nose pliers I pushed down on one corner of the topmost rib and slid it into the hole rotating the clip like a screw. I did that for each rib and got it out in one piece!
Still need that one I ordered though, to replace the one I broke.
Old 09-26-2019, 12:19 AM   #5
focusofheart
I found the ACDelco Retainer (Part #12084149) at O'Reilly's Auto Parts for $5.49 if that helps.
Saturn 1998 - SL2 automatic
Old 09-26-2019, 04:56 PM   #6
hholbein
Originally Posted by TwoFistedJustic View Post
I'm replacing my vapor canister purge solenoid because I have the starter off anyway ....
I don't seem to recall that Saturn Evap Canister purge solenoids are failure prone from past forum posts, but I could be wrong. (Certainly they seem to have a better track record than Chrysler!) I do seem to recall some sporadic issues with Evap and the filler neck preventing normal refueling. You might want to keep the OEM part just in case the replacement item isn't as robust as the original.
Old 09-26-2019, 05:27 PM   #7
TwoFistedJustic
It didn't fail. Nothing wrong with the old one that I know of. But new ones are $20 from Standard. They are easier to replace with the starter out than in, so I preemptively replaced it.
Old 09-27-2019, 07:34 AM   #8
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
I had a stubborn P0440 code that wouldn't go away despite swapping the fuel cap a few times. Replacing the Evap canister purge solenoid finally cleared it.
Goggles Pisano is offline   Reply With Quote
Old 09-27-2019, 04:04 PM   #9
TwoFistedJustic
I had that same stubborn code on mySC2A. I replaced the solenoid only to discover that the vacuum tube running from the solenoid to the throttle body had pulled out of the throttle body, which it can do very easily just from normal engine vibration. Now when I see a P440 that little tube is the first thing I check, and it's usually the culprit.
Old 10-04-2019, 09:25 PM   #10
TwoFistedJustic
ACDelco 12084149
This replacement clip fits perfectly. And its easily removable
Electrical Connectors: How do they work? cindycated Astra Tech 2 06-21-2013 10:46 AM
Alternator Electrical Connectors 95 SL1 SL Road dog S-Series Tech 2 09-23-2011 12:42 PM
Proper method to clean electrical connectors. postmortal1 S-Series Tech 7 03-15-2010 10:21 PM
Horn is bad, is it ok to put electrical tape over connectors for a few days? 2002SaturnMan S-Series Tech 4 05-31-2009 10:31 PM
How do I remove electrical connectors off of fuel injectors? flyhop S-Series Tech 3 04-05-2006 07:04 PM
