Old 11-05-2018, 01:56 PM   #1
manualvue
manualvue is on a distinguished road
Dizzy flicking dash lights engine light after driving 30m
I saw a post somewhere where someone stated almost exactly my current problem, except the thread has 12 pages and start date was 2008. Hard to read everything. One thing that is super frustrating is when people post incomplete information about the vehicle they are talking about!! Please state type, year, etc. before posting the problem! I don't want to read a long post about a car with auto transmission if I have a manual.
Anyway, mine is a 2003 VUE, 2.2L, manual, and 4 cyl. This year, I replaced the starter, the catalytic, alternator and last, the transmission. I just can't afford to get another car with unknown issues so I keep patching this 15 yr old! Plus, I really love the interior with no blind spots and the exterior! When the alternator went, my dashboard lights went on and off, steering (which is electric) would fail while driving and car would not accelerate. The alternator replacement seemed to fix this. Except, the first day I drove it, the lights flashed on and off, but did not happen again. I figured the computer was resetting or something? Lights flashing happened again months later while driving over 70. But not always. Now, when driving one night for over 30 minutes or so, the dashboard went crazy blinking, inside lights blinked, check engine lt came on and stayed on. I panicked completely fearing it would stall. Did not seem to lose power but the steering went for a while. After the car was off for about an hour, it started fine, steering fine, check engine lt still on. It does not happen when driving to/from work (less than 30 min drive) but it happened on Halloween after driving over 25 min, check engine lt came on again (i had had it checked and turned off after codes said lost comm with bcm). Drove fine next day and engine lt went off by itself. My mechanic needs to hire a freelance guy who does electric diagnostics and charge $150 just to see where the communication problem is.
If it was a short, why will it happen only when car running over 30 min? if it is a ground issue, again why act up after some time of driving and not right away?
Should I bypass the diagnostics and go straight to buying a bcm to replace current one? Or, could it be something simple? I just want this car to last until I retire next year without too much extra fixing! Help! The guy that worked on the car with the alternator prob. left a couple of things unhooked, (button horn cable and coolant receptacle hose) so I am wondering if they might have left something off after the transmission replacement and I did not know because I drive less than 30 min at a time most days. Only found out after driving to the airport which is more than 30 min drive. I have had the wrench light on for years and the security lt came on over a yr ago. I don't care if they stay on if it does not affect anything else, which seems not to. I am finally going to replace the ignition lock under the recall secretly hoping that it might fix it but know it won't. Go straight to BCM replacement? Why act up after 30 min driving? Thanks, loyal vue people.
manualvue is offline   Reply With Quote
Old 11-06-2018, 02:27 PM   #2
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: flicking dash lights engine light after driving 30m
Don't know if you have sunroof - or perhaps a roof or windshield water leak - but one of my kids recently had the crazy dashboard and interior light problem with 2006 Vue.
We found a very small amount of water in connector C200. This is behind kick panel next to drivers left foot.
You (or mechanic) could get access to the connector - its a simple process to release two parts - and used canned air to dry contacts on both side of connector.
This was a cheap fix for us.
And by the - way we concluded the primary contacts causing trouble were two data-bus wires (CAN high and low) which transport information between BCM and ECM/PCM and IPC (dashboard).
I can email instructions to remove the kick-panel and applicable interconnecting wiring diagrams. PM email address if you'd like to have.
Old 03-02-2019, 10:17 AM   #3
manualvue
I meant to thank you for taking the time to answer, if a bit late, thanks!
I have a no frills Vue, no power windows or locks, no fancy equipment. I got it cheap at the end of the year at the dealer.
I have always felt it acted like a lose connection somewhere, as it started with the horn sticking to the point I had to remove the relay and bypass it, then the DRL lights would come and go, again as if a wire was lose. They work sometimes but most times they don't. That has been for years. No big deal. But this flickering of dashboard and inside lights, does not affect headlights though, and if it happens long enough, the power steering seems to go. The check engine comes on. I had to muscle the steering to drive. The next day, all is well, check engine light. goes away. I might not have a problem for weeks which makes it so hard to diagnose. I recently noticed that the odometer stopped turning. I just don't understand if it is ECM, BCM or lose wires. Car is 15 yrs old in many parts still, feels like half of it has been repaired. I would like an answer that is not super expensive to diagnose. Going on an exploration of systems, replacing things as they go, to find if that was the problem, seems expensive to me!
Old 03-05-2019, 12:33 PM   #4
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Regarding DRL - can you determine if headlamps are actually failing or if its just DRL indicator on IPC (dash)?
Loose wiring can be a real challenge to track down and my prime search area based on your symptoms would be back side of IP fuse block as I've ran across several poor connections in this area.
You can reach thru the small IP fuse/relay access door (next to front pax left foot) to wiggle wiring harnesses on back side of fuse/relay block.
My preferred method is to remove drivers side center console panel so I can carefully handle various harnesses leading to fuse/relay block while monitoring IPC and inside lighting for intermittent conditions.
Old 06-12-2019, 12:45 AM   #5
JimY
JimY is on a distinguished road
2002 VUE 3.0L
far2grumpy: 2002 VUE V6 AWD: Thanks for suggesting IPC and BCM issues might be related to C200. My problems began when a repair shop opened up C200 and cleaned some contacts therein per a TSB for a Throttle Body issue they were addressing, and filled C200 with dielectric grease. Maybe too much of it?
I've an intermittent issue: Security light blinking on for 2 seconds occasionally and miles deducted from odometer value...(and sometimes complete crash of BCM..reset-able so far without any evidence of BCM damage). Thanks. I'm going to blow the dielectric grease out of C200, with canned air, and have a good look. I don't have a sunroof. Everything looks very clean and dry in the C200 area.
JimY is offline   Reply With Quote
body control module, dashboad lights, long drive
random dashboard flicking , radio dash light out, cigarette bulb light out hlouis89 S-Series Tech 13 03-22-2014 04:27 PM
Dash lights flicker-while driving and even after shut off buyavue Vue General 7 11-27-2013 02:17 PM
No dash lights/ Tail lights/License plat light jmelvin L-Series Tech 6 02-20-2012 03:41 PM
Security light on dash blinks while driving birdieluvr76 Vue Tech 6 05-23-2007 07:54 AM
2005 relay headlight & interior lights flicking bryce Relay General 3 05-18-2006 08:49 AM
