#1 |
![]() Join Date: Dec 2015
Hello,
About a month ago my car threw a p1174 code. Since then I've noticed that the rpm hangs at 1400 when coasting in neutral, and will drop to idle when the vehicle stops. The problem appears to be intermittent, and I can't figure out under what conditions it occurs. Any ideas on how to correct this issue? Thanks, SaturnFans! 2006 ion3, 2.4l |
#2 |
http://m.greatautohelp.com/questions...aturn-ion.html
Ignore the problem any longer and tipu will blow up your engine
2007 Saturn Ion 2 2003 Chevrolet venture lt trifecta dealer for the U.P. and WI. There is no two door ion. Proudly driving one of the last saturns produced before gm killed the brand. |
#3 |
Could you explain what is causing the issue exactly? The cel went off and has not come back on.
Thanks |
#4 |
The link explains it just fine (that's why I put it in my post), but basically, fuel trim balance is off, some cylinders are getting more fuel than others. There is no void reason for this besides bad/plugged injectors. Injectors in l61/le5/lsj engines are known to plug/go bad. This is why there is a tsb stating to use top tier gas in these engines. Replace the old design injectors with the new ones and get the ecu flashed.
#5 |
Thanks man. If I use top gas and fuel injector cleaner, can I put off swapping out the injectors for a bit?
#6 |
I wouldn't. The damage is done, and likely permanent.
Bookmarks |
Hanging RPM, p1174 Code. | Cronusheart | S-Series General | 1 | 12-30-2015 02:02 PM |
Help! P1174 | AlyDot06 | Ion Tech | 1 | 10-03-2011 03:13 PM |
P1174 code help please!! | chief58 | Canadian Saturn Owners | 2 | 03-20-2011 04:42 PM |
DTC code P1174 | Ctaylor | Ion Tech | 29 | 09-12-2010 05:49 PM |
Speedometer hanging up? | Oceanair | S-Series Tech | 3 | 11-11-2006 10:14 PM |
