Old 09-29-2014, 06:27 PM   #1
ZKdawg
ZKdawg is on a distinguished road
ZKdawg's Avatar
2004 ION-2 Quad Coupe
Question stalling auto... alt???
car stalling and wont start after.
seems like i have no batt. juice but it is brand new.
the starter will just click.
i can jump the car and fun it but not sure how long as i would just put it in the garage.
now, im sure this is the orig. alt and i think it isnt charging the batt..
i checked it with the volt meter and after jumping it and getting it in the garage, it was 12.5v.
9-24-14
This is the day i finished the af23 QC tranny swap... yeah
9-25-14
It ran like a beauty
ZKdawg is offline   Reply With Quote
Old 09-29-2014, 10:41 PM   #2
ZKdawg
ZKdawg's Avatar
Default Re: stalling auto... alt???
could really use some help.
9-24-14
9-25-14
Old 09-29-2014, 11:05 PM   #3
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
If you measured 12.5 volts with the engine running, that sounds like a bad alternator to me. If measured with the engine off, that's about normal for a charged battery with no load.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles
2018 Chrysler Pacifica Touring L 48K miles
Old 10-01-2014, 11:05 PM   #4
ZKdawg
ZKdawg's Avatar
it was with the engine off and just after i jumped it.
i have the alt tested and it is good.
9-24-14
9-25-14
Old 10-02-2014, 08:06 PM   #5
ZKdawg
ZKdawg's Avatar
plz need help...
i just out the alt back in and made a ground from it to the body.
i just need some time tomorrow to jump it and see if it was just bad grounds.
any ideas why the batt would drain other wise?
9-24-14
9-25-14
Old 10-03-2014, 02:09 AM   #6
Eliminating the battery and alternator leaves wiring and starter. With no history given for this car (mileage, maintenance done, parts replaced), a worn out starter may be a possibility.
Old 10-03-2014, 12:43 PM   #7
ZKdawg
ZKdawg's Avatar
ill look into that.
would that drain the batt.?
my starter works as long as there is juice.
somthing seems to be draining the batt. and killing the car while driving then wont start with out a jump.
9-24-14
9-25-14
Old 10-03-2014, 08:02 PM   #8
ruley73
ruley73's Avatar
Originally Posted by ZKdawg View Post
ill look into that.
There is nothing on the car that could be draining the battery if your alternator is working properly. Of course, this is assuming that you don't have a 30,000 watt stereo or any other power hungry accessories installed.
Did you remove the alternator and have it bench tested or was it tested in the car? If it wasn't bench tested I'd get that done and go from there.
Old 10-03-2014, 09:53 PM   #9
ZKdawg
ZKdawg's Avatar
LOL... YOUR FUNNY!!!
i had it tested at advance auto and we did it 3 times to make sure.
other then that i just remembered there was what i think is a ground when i was putting the harness in right next to the coil plug and it has to blk wires going to it that i will get a pic of tomorrow.
i grounded it to the engine head.
is that right?
9-24-14
9-25-14
Old 10-03-2014, 10:01 PM   #10
ZKdawg
ZKdawg's Avatar
found this
its #21, just follow the arrow.
this is what i grounded to the head.
9-24-14
9-25-14
Old 10-06-2014, 10:17 AM   #11
ZKdawg
ZKdawg's Avatar
need help plzzzzzzz.
9-24-14
9-25-14
Stalling mwayne5 S-Series Tech 6 02-27-2012 06:22 PM
200 LS2 Stalling tomdorich L-Series Tech 3 09-30-2011 05:41 PM
1997 saturn sc2 auto stalling out 1997SaturnTitan S-Series General 10 04-20-2011 12:33 AM
Almost Stalling, Sometimes.... bigboy55693 S-Series Tech 1 07-09-2009 04:40 PM
Stalling TPS? LinuxPunk S-Series Tech 7 09-14-2006 11:01 AM
