Old 09-24-2014, 12:13 PM   #1
ZKdawg
ZKdawg is on a distinguished road
ZKdawg's Avatar
2004 ION-2 Quad Coupe
Attention trans swap now no start... HELP
i just got the af23 swap done and the thing wont start.
when i try to start the car it would even crank.
i got a remote starter button and it started for a sec then stopped.
now the passlock sym. is on and it says to service car and pwr str is on the info torn as well.
i am trying the passlock relearn right now but is that my problem?
also before i started it with the remote i could use my elm scan 5 but after i can connect to the ecu????
could that have something to do with the passlock?
any help would be awsome and thankful.
ZKdawg is offline   Reply With Quote
Old 09-24-2014, 02:03 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: trans swap now no start... HELP
Double check the under hood wiring that you unplugged. Also, try disabling the remote starter, they are nothing but trouble on newer gm cars.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 09-24-2014, 02:04 PM   #3
2006 ion2
2007 ION-2 Sedan
If all this checks out, it sounds like a passlock issue. Is your car pre or post recall?
2007 Saturn Ion 2
Old 09-24-2014, 02:15 PM   #4
ZKdawg
ZKdawg's Avatar
i have one of those starter jumpers to turn over the engine from under the hood not the key fob remote start.
also, i have no spark.
is that from the passlock?
i tried the passlock relearn but after 10+ min the light never turn off????
Old 09-24-2014, 02:41 PM   #5
ZKdawg
ZKdawg's Avatar
im trying the relearn again the right after i started the light turnd off but still no start????
Old 09-24-2014, 04:05 PM   #6
ZKdawg
ZKdawg's Avatar
**************************update****************** **********
i disconnected the batt and took all the connectors off the pcm and tcm, blew them out then put everything back together and it started.
Ran for 8-10 min then stalled.
Turn the ign. Off and tried to start and the starter clicked then a sec later started.
Old 09-24-2014, 06:45 PM   #7
2006 ion2
2007 ION-2 Sedan
Pre or post recall?
2007 Saturn Ion 2
Old 09-25-2014, 04:46 PM   #8
ZKdawg
ZKdawg's Avatar
Happy Re: trans swap now no start... HELP
pre.. i dont plan on doing any recalls as i bought the fix and sell.
i just took it on its first test drive and no codes or other light are on.
it runs great and shifts smoothly.
my starting problem was a bad batt..
Old 09-25-2014, 04:59 PM   #9
2006 ion2
2007 ION-2 Sedan
It's free maintenance you can use as an excuse to ask more for it, but you can't be bothered?
2007 Saturn Ion 2
Old 09-25-2014, 05:24 PM   #10
kevin.st56
kevin.st56 has a spectacular aura aboutkevin.st56 has a spectacular aura about
kevin.st56's Avatar
2003 ION-2 Sedan
unless he doesnt plan on waitin a month for the parts to be available to have te recal performed. it been almost a month for me since i submitted my request for it.
03 ion-2 Sedan 5sp
94 Honda civic automatic "VTEC yo"
05 Santa Fe 2.7L (Fefe) {Wrecked}
"A problem clearly stated, is a problem half solved."
♕KCCO
kevin.st56 is offline   Reply With Quote
Old 09-29-2014, 03:58 PM   #11
ZKdawg
ZKdawg's Avatar
i also dont have a tag on the car.
9-24-14
This is the day i finished the af23 QC tranny swap... yeah
9-25-14
It ran like a beauty
Can I swap 2002 DOHC SC Auto trans swap into 2000 SOHC SL? fbr S-Series Tech 3 07-17-2014 10:08 PM
Cvt trans swap Cavell Vue Tech 8 03-06-2014 10:53 PM
What's easier: 5th Gear Swap or full Trans Swap Tatohead S-Series Tech 6 07-30-2013 12:51 PM
trans swap Keej S-Series Tech 5 12-01-2006 07:43 PM
96 SL1 w/ MP7 TRANS??? PLZ HELP!!! SWAP PCM FROM DOHC???? SWAP BOARDS??? randyshear S-Series Tech 20 11-15-2006 05:58 PM
