Old 09-18-2014, 07:55 AM   #1
ZKdawg
ZKdawg is on a distinguished road
ZKdawg's Avatar
2004 ION-2 Quad Coupe
Question random codes
when i bought this car a few weeks ago, it had a bad trans along with these codes.
i know there because of the bad trans, i think, but i just want to know what they mean.
i found a few of them but need the rest.
p0700 Transmission Control System Malfunction
p0841 Transmission Fluid Pressure Sensor/Switch A Circuit Range/Performance
p1758
p1883
p1884 TCC Enable/Shift Light Circuit
p1885
p1886 Shift Timing Solenoid
p1888
u2105
any help would be appreciated.
P.S. i have another post on needing help with removing the shift cable bracket as i am in the mid of the af23 swap and going back to the junk yard
(JY) to get it.
if u could just read and comment with any help, i would really really be grateful.
ZKdawg is offline   Reply With Quote
Old 09-18-2014, 03:00 PM   #2
kevin.st56
kevin.st56 has a spectacular aura aboutkevin.st56 has a spectacular aura about
kevin.st56's Avatar
2003 ION-2 Sedan
Default Re: random codes
i started looking for the codes, and from what im finding, you have the dreaded CVT tranny. long story short, your better off replacing it with a different auto, but not with another CVT, unless you want to go through all this again.
03 ion-2 Sedan 5sp
94 Honda civic automatic "VTEC yo"
05 Santa Fe 2.7L (Fefe) {Wrecked}
"A problem clearly stated, is a problem half solved."
♕KCCO
kevin.st56 is offline   Reply With Quote
Old 09-18-2014, 06:27 PM   #3
2006 ion2
2007 ION-2 Sedan
Replace the known bad transmission, clear the codes, then see what pops back up.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 09-19-2014, 12:20 PM   #4
ZKdawg
ZKdawg's Avatar
obviously u guys didnt read the whole post...
i am doing the swap right now and just want to no the def. of the codes i got for me, my self, and I.
Old 09-19-2014, 03:01 PM   #5
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
this is what i found. took a lot of digging on google and bing.
p1758 - Transmission Range Switch - Drive Without Drive Ratio
p1883 - i get redirected to code p1882 instead, which is "Ratio Control Performance will set as a result of the variable pulley being broken or improperly assembled"
p1885 - Transmission Transfer Case Disengaged Solenoid Short to Ground (this one didnt say what manufacture vehicle this is for)
p1888 - Torque Converter Clutch Enable Solenoid Control Circuit Low Voltage
u2105 - Lost Communication with Engine Control System
All are dealing with the CVT. Happy swapping
03 ion-2 Sedan 5sp
♕KCCO
Old 09-19-2014, 03:55 PM   #6
ZKdawg
ZKdawg's Avatar
thx for that and i have the trans and motor back in.
all i have to do is hook all the connectors back to the eng ant trans and fire it up.
Rep. +
Random misfire codes lost2a6 L-Series Tech 7 08-04-2012 10:27 AM
Help! Service Vehicle Soon Light with Random and Undefined Codes brntstauf Vue Tech 30 08-29-2009 09:16 AM
somewhat random dorisSL S-Series General 7 04-03-2009 05:55 PM
random MM96 S-Series General 0 06-20-2007 10:09 PM
Got my codes read.. the autozone rep was surprised to see soo many codes... oh no bskicrash1 S-Series General 2 11-12-2006 02:10 PM
