Old 02-19-2014, 07:18 PM   #301
NickL30
NickL30 has a spectacular aura aboutNickL30 has a spectacular aura about
NickL30's Avatar
2004 ION-3 Quad Coupe
Default Re: VTi to AF23 transmission swap
Sonds like a pretty good deal. I bought my car with an unfinished transmission swap. Went from auto to a manual transmission and they never swapped the computer. Good job on seeing it all the way through!
NickL30 is offline   Reply With Quote
Old 03-05-2014, 11:42 PM   #302
grasshopper
grasshopper is on a distinguished road
Hey just an update. All my problems were from not using same tcm with same transmission. If you buy a tcm from one car and transmission from another they will cause funky stuff most times. If you use a matched set from an existing 4 door it will always work flawlessly.
grasshopper is offline   Reply With Quote
Old 03-17-2014, 02:59 PM   #303
g_munk
g_munk will become famous soon enoughg_munk will become famous soon enough
Hi grasshopper,
I still havent gone to get my tcm reprogrammed, because I was thinking the other day that maybe I could pick up two more tcms, one from 2003 and another from 2004..... but from what you had just posted, I would need the exact tcm from the car my transmission came out of.... blah I might just deal with the huge knock
Thank you
g_munk is offline   Reply With Quote
Old 03-18-2014, 11:54 AM   #304
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
Originally Posted by g_munk View Post
Hi grasshopper,
Thank you
You don't need the exact same one. Just one that had the same options, for example if your car has air, the TCM should come from a car that has air. I think reprogramming should take care of this. But, hey, who am I?
chilipepper1327 is offline   Reply With Quote
Old 03-18-2014, 10:02 PM   #305
g_munk
Thank you looks like I am going to try the reprogram route then first.
Old 03-18-2014, 10:03 PM   #306
col_dude190
col_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura about
2006 VUE Red Line
Hi grasshopper,
Thank you
If your transmission is shifting through all gears and you do not currently have a check engine light telltale illuminated, then your TCM is more than likely fine.
I'm not sure how familiar you are with the history of the AF23, but GM had A LOT of difficulty with the initial programming for the AF23 and it's big brother the AF33. Early '02/'03 V6 Vues and '03/'04 ION's had a lot of issues early on with shift flares and "drivability concerns" due to this poor transmission software.
GM finally got it right, but there were several owners who in the early days of the ION had their TCM's reprogrammed multiple times to address poor shift quality and odd transmission behaviors.
If you do not currently have any check engine lights related to transmission codes, I would recommend that you take your ION to your local GM dealer, or a mechanic with access to a Tech Tool 2 and GM SPS. They will need to do two things for you- 1) reprogram your TCM with the most current version of the AF23 software from SPS 2) reset the transmission adaptives in the TCM using the Tech Tool 2.
You will need to take a VIN number from an '03/'04 ION sedan (with an automatic transmission) with you, preferably from the same model year as your vehicle. The dealer tech will need to enter this VIN number into SPS to pull up the appropriate programming for the AF23, since your quad coupe did not originally come with this transmission. They will then reprogram your TCM from SPS. The transmission adaptives are then reset with the Tech Tool 2 to basically force the TCM to relearn all of it's shift patterns as if it were a new vehicle.
These two steps should resolve your knock/clunk. In my experience this is seldom a fault of the TCM, but rather an issue with the software stored on the TCM.
I've attached the service manual document on resetting the transmission adaptives in case your dealer/mechanic has any question on what needs to be done.
col_dude190 is offline   Reply With Quote
Old 03-24-2014, 06:38 PM   #307
Bowdiddly
Bowdiddly is on a distinguished road
Happy Re: VTi to AF23 transmission swap
I just wanted to give you guys a shout, and a big thank you! I have an 03 ion that I love, it had just rolled to 130,000 miles and the tranny died. I took it to the shop and they could not find the M75 anywhere. I finally found one for $2800, and was floored. I thought that it was the end for my "lady in red". I even called to get a junk price. Then I did a little research and found out what Saturn had done with a couple of these years and mine was one. I read this post several times and started searching. I found a donor car with 60k miles and went for it. Luckily the mechanic was willing to try something new.
After a few days of trial and error, we got her running
. I am happy to say that the first 60 miles have been pretty smooth, the only issue i could bring up would be a little rough shifting in the city, between first and second gears. Other than that, it runs better now than before!
Oh, and total we spent less than half of what another "bad" tranny would have cost!
2003 Ion automatic
Bowdiddly is offline   Reply With Quote
Old 03-27-2014, 05:20 AM   #308
Izzy21
Izzy21 is on a distinguished road
Izzy21's Avatar
2003 ION-2 Quad Coupe
Its so weird to see all the postings On the TCM and everything to be year specific. Ive done many swaps with all my parts mismatched and had no problems at all. At least not software related. Ive just had problems with wires being cut and a trans solenoid being busted because of a crash. I just finished another quad gotta love this site!
Izzy21 is offline   Reply With Quote
Old 03-27-2014, 09:26 AM   #309
chilipepper1327
You know what makes these cars pop? It is a subtle thing but really makes a difference. Paint the mirrors and the small rectangular piece, body colour. BIG difference. Take a look at mine.
Old 03-27-2014, 10:42 AM   #310
mikec
mikec will become famous soon enough
mikec's Avatar
It also helps to have a nice color like chili pepper red,
mikec is offline   Reply With Quote
Old 03-27-2014, 06:03 PM   #311
chilipepper1327
Only because this car kinda fell into my lap. When I first saw it, I had no idea what car it was, but I knew I had to have it(it was on a dealer's lot).
My 06 is Pacific Blue. Hmmm, maybe I should change my user name to pacific1327! lol!
Old 07-06-2014, 07:45 PM   #312
tck9173
tck9173 is on a distinguished road
I have almost pulled off the swap in my Ion but I have come into a problem. A code comes up that says communication with the TCM was lost. I have tried two different TCMs and the same thing happens. I bought a brand new wiring harness so I'm not sure what it could be. Any help is much appreciated.
tck9173 is offline   Reply With Quote
Old 07-14-2014, 01:34 PM   #313
g_munk
it sounds as it there is an open circuit somewhere, take your voltmeter and check continuity in the harness
Old 08-08-2014, 07:26 PM   #314
gonekrazy14
gonekrazy14 is on a distinguished road
Originally Posted by Orion FE View Post
I've recently purchased an 04 Quad Coupe and I almost positive from reading your blog, it's a VTI, being that and most of what I read, all QC's come with the VTI. How can I tell the difference in a VTI and an AF23 transmission, externally looking.
Thought the deal on the ION was unbelievable, so I got it. The car is in immaculate condition, leather, sunroof, power everything, one owner, etc., so for $1,200, I couldn't pass it up. The tranny is inop, (won't go into any gear) so I've read your entire blog and it sounds pretty simple.
This is my first ION experience, as I have dealt with MANY "s" series cars over the past 6-8 years and those tend to be my favorite.
Anyway, I enquired to some other Saturn enthusiasts as to why wouldn't some other tranny work in the ION and they were lost as well. Can't wait for them to read your swap blog.
Thanks!
I purchased a 2004 ION QC 2 weeks ago with the VTI. Did not know about these tranny's just got it cheap. Today I went to purchase an M43 from what I thought was a 4 door ION. Guy told me he had 2 cars and after looking at the pics one was a 2004 QC with M43 on trim tag and VIN. It is a factory installed M43 in a 2004 QC. I purchased the tranny and everything to make the swap including the shifter.
gonekrazy14 is offline   Reply With Quote
Old 08-12-2014, 11:09 PM   #315
ShawnL
ShawnL is on a distinguished road
does anyone have the rear mount, (part that bolts to the transmission , and the front mount for a af23? I need one of each to complete my project. thanks Shawn
ShawnL is offline   Reply With Quote
Old 09-15-2014, 02:41 AM   #316
Izzy21
Izzy21's Avatar
Do you need the rear trans mount or bracket?
Old 09-16-2014, 03:42 PM   #317
ZKdawg
ZKdawg is on a distinguished road
ZKdawg's Avatar
2004 ION-2 Quad Coupe
when it comes to the shift cable bracket, how do u get it off the cable and will the vti cable work or do i need it from the 23 to?
ZKdawg is offline   Reply With Quote
Old 09-16-2014, 09:10 PM   #318
355vette
355vette is on a distinguished road
Im currently doing this swap but a little confused about the harness. Do i just need a trans harness or!an engine harness too? I can find new trans harness for 100 bucks but cant find any used engine trans harness combos
355vette is offline   Reply With Quote
Old 09-17-2014, 07:53 AM   #319
ZKdawg
ZKdawg's Avatar
its all one thing, found that out when at the junk yard last week
Old 09-22-2014, 04:24 PM   #320
tamp
tamp is on a distinguished road
I remember reading that you need to take apart the place where the trans wiring goes into and replace it with the new wiring.
tamp is offline   Reply With Quote
ID the AF23 Transmission 79sc2 Ion Tech 3 10-06-2010 07:21 PM
2003 Ion 1 AF23 5spd Transmission jkenley Ion General 2 10-06-2010 07:15 PM
ION Transmission swap for vue with Vti? kim_lombard Vue General 2 07-11-2009 11:08 AM
VTi vs AF23 axles jeepinwi Ion General 1 11-26-2008 01:42 PM
VTI Transmission swap out Doug Woolf Vue General 3 07-13-2004 01:24 AM
