Old 11-15-2012, 01:25 PM   #1
saturnhusker
saturnhusker is on a distinguished road
saturnhusker's Avatar
2000 SL
Default Speedo vs GPS
Ok I have a 2000 sl 1.9 base no ps. The tires that are OE are 185/65 14 well when I ran them the speedo was under what my gps was showing. I had to go like 63 on speedo to show actual speed on gps as 60. Ok running on interstate @ 75 rpms was at 2850. Now have 195/70 14 on there and have to go under the speedo going 60 gps said I was going 63. Rpms are down on all speeds. I aint changing the tires cause they are my winter tires I wasn't going to pass up deal on blizzaks cause they weren't the correct size tires. But speedo was off when I had oem tires on there do I need to replace speedo?
saturnhusker is offline   Reply With Quote
Old 11-15-2012, 02:35 PM   #2
Default Re: Speedo vs GPS
My code reader says the PCM/VSS is showing 70mph while the speedometer is showing 67mph. In this case, GPS is overkill for proving just how inaccurate the gauge's are from the factory
Old 11-15-2012, 03:59 PM   #3
Google information. You'll find that car makers gave us a fudge factor; speedo reading will be higher than actual speed so this gives everyone a margin of error when using posted speed limits. No one replaces their speedo just because its 'off' a little. A difference of a few mph isn't going to warrant a speeding ticket.
Old 11-15-2012, 05:03 PM   #4
adventureoflink
adventureoflink's Avatar
not to mention too, the officer's radar gun may also be slightly off as well...
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 11-15-2012, 05:51 PM   #5
toggenburg
toggenburg's Avatar
Traditional radar guns are not likely to be off at all, that is if the officer takes the time to calibrate.....in most departments I am sure it is still mandatory to calibrate, to ensure that a speeding ticket is not thrown out by a judge.
Before shift use, they are calibrated with the supplied tuning fork.
Yep, the tuning fork's perfect pitch is what was used to calibrate.
Most units I have seen lately, still use the same method.
However, Vascar, X band and beyond, laser or infra-red, who knows what they use for calibration.
Old 03-14-2013, 01:27 AM   #6
saturnhusker
2000 SL
Well winter is nearly over and I just put on new 195/70 14's Kumho Solus KR21 cause I like the tread design. I was on my way into town and they have them radars on to show your speed so I stayed at what GPS said was 65 and what do you know radar gun was reading the same thing. I have done this experiment more than once and always read the same. I get around 37 mpg @ 75 mph on the interstate. I know it will go up cause the days are warming up and winter fuel is changed to summer. Plus that was with my Blizzaks on not a great highway tire. I will be back in to the mid 40's again if not higher.
Old 03-14-2013, 07:51 AM   #7
It is not the speedo, the mpg/1000 RPM is programmed into the PCM and tire diameter is part of the calculation. Changing tire diameter changes the resulting speedo reading and there is no way to correct it. As also mentioned, the speedo usually reads slightly low by design with the stock tires (diameter) but not necessarily the stock tire size as tire size(diameter) as this diameter does vary slightly with brand and tread pattern/design.
Old 03-14-2013, 08:08 AM   #8
TXSaturn02
TXSaturn02 has a spectacular aura aboutTXSaturn02 has a spectacular aura aboutTXSaturn02 has a spectacular aura about
TXSaturn02's Avatar
How can you blame the speedo and not the GPS? The car and tire are firmly planted to the ground (if you don't drive like a maniac) with the wheels turning and calculating constantly. The GPS? It is using radio signals that are being transmitted every few seconds (depending on the quality of your unit) AND the GPS does not account for variations in elevation.
I guess the old adage, "The bigger the lie..."
2002 SL2 Manual - new in November, 2001
As of 09/30/17: 223,751 Miles - SOLD
New owner report of 08/08/19: 234,408 Miles
2013 Mazda 3 HB - new in October 2012
As of 07/25/18: 51,495 Miles
TXSaturn02 is offline   Reply With Quote
Old 03-14-2013, 10:32 AM   #9
Stop watch and mile markers works well and will yield similar results.
Old 03-14-2013, 10:37 AM   #10
bumpdraft
bumpdraft's Avatar
1998 SW2
What about Radar Speed Trailer reading?
picture of Trailer:
westernstates.org/projects/coats/Updates/2011-09-01.html
My spedometer seems to match the trailer's number.
Old 03-14-2013, 11:03 AM   #11
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
speedo and odometer change as tire wears also. new tire has a much different turn per mile than worn tire.
Old 03-14-2013, 12:05 PM   #12
DonP
1995 SL2
Tire revs per mile will vary with tire size, pressure and wear.
On most of my cars the speedometer has generally read about 2% to 3% higher than doing the milepost/stop watch on the interstates. That is with the OEM standard tire size mounted. The GPS-reported speed was closer than the speedometer.
Never got a speeding ticket as a result of speedometer inaccuracy.
Old 03-14-2013, 01:07 PM   #13
saturnhusker
2000 SL
Well when I had the oem tires on they registered slower the than the speedo and the result was higher rpms. Changed tires still off but rpm's lower with the bigger tire size. I have put on 22k since august I keep a milage log and with the change in tires my mpg went up and rpm's went down.
Old 03-14-2013, 02:27 PM   #14
There are PCM calibration options and it is entirely possible that is incorrect. There could be a long list of reasons for that. For every set of tires you should calculate an odometer reading correction factor multiplier and the same for the speedometer as they are usually different.
Old 03-19-2013, 12:24 AM   #15
saturnhusker
2000 SL
Well it's winter and with the change of tires mpg gallon went up. Then we had a couple of days of temps in the 70's and I travel for my job well when I got there I still had 1/4 tank and had gone 375 miles a big jump from last summer. I have not done anything but change my oil every 3k.
94 SC2 No Speedo BOZZZ S-Series Tech 4 10-30-2008 12:30 AM
speedo maxwedge1964 Vue General 14 11-10-2005 04:52 PM
Help me fix my speedo! please! sps SOHC Miscellaneous Tech 3 11-17-2004 09:37 PM
bad speedo sl2hippie S-Series General 6 12-29-2003 01:00 AM
speedo?! silverblue02 S-Series General 12 08-03-2003 04:31 PM
