Old 06-05-2007, 04:07 PM   #1
mudnsoccerguy
mudnsoccerguy is on a distinguished road
1996 SL2
Default Uneven Tire Wear
I was replacing my brakes today, when I discovered that my rear tires have the inside of them worn down to the steal belts. These tires are about 6 months old so it has me a little alarmed. I've searching on the forum and have found the most likely culprit to be a horrible alignment problem. Before I take it into the shop is there anything else it could be, so that I know they're on the up and up? Thanks in advance.
1996 Saturn SL2 90k miles, 3rd owner
mudnsoccerguy is offline   Reply With Quote
Old 06-05-2007, 06:37 PM   #2
Rog02
Rog02 is on a distinguished road
1994 SC2
Default Re: Uneven Tire Wear
Probably alignment unless you have been moonlighting using your Saturn as a dump truck. I started showing some unususal tire wear on mine when I was traveling all the time with the trunk loaded down with 400 lbs. of tools and equipment. That job came to an end and I got to unload the car problem went away. I checked the alignment loaded and unloaded. the alignment change was drastic.
I'm OLD, I'm TIRED, and I'm GRUMPY
Roger
Rog02 is offline   Reply With Quote
Old 06-05-2007, 10:13 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
I'm guessing the uneven tire wear is from alignment or incorrect tire pressure.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 06-06-2007, 10:48 AM   #4
BarnOwl
BarnOwl's Avatar
2000 SW2
Might just be alignment but, I'll bet it's a tie rod end or ball joint. Take it in for an alignment and they'll tell you if there's a problem like that.
Uneven Pad wear bboy29 S-Series General 6 12-03-2009 04:15 AM
very uneven brake wear Phredawgy S-Series Tech 17 01-12-2008 05:08 PM
Uneven Tire Wear, Best Replacement Tires eibbor L-Series Tech 2 05-28-2007 10:40 PM
Uneven wear on all tires peccles Vue General 12 06-28-2005 12:06 AM
Uneven tire wear traced back to overinflation at factory. Any recourse...? nutrock69 Vue General 40 09-19-2004 06:50 PM
