Old 07-01-2006, 10:45 AM   #1
johnt671
johnt671 is on a distinguished road
Question 92 Sl1 four way flasher problem
While trying to replace some bulbs in my instrument cluster the "easy " way I some how broke my 4 way flasher lights. As I have the problem with my ignition switch that allows the warning chime to go off all the time I got tired of listening to the noise and decided to make it stop. I felt around the fuse box until I found a vibration and started to pull out what I thought was the chime box. Turned out to be the turn signal and 4 way flasher relay. It pulled out crocked because it had a clip on it to hold it in. After pulling it out and putting it back in my turn signals and flasher didn't work.
I found the switch for the flashers was half on and half off, so I switched it off which let the turn signals work again, but when I turned the flashers on I get a buzzing noise from the relay. Thinking I screwed the relay up I went to the auto parts and got a new one, but I still get the buzzing noise and no flashers .
Not sure what I broke and hope someone can help me out. Thanks.
Add to johnt671's Reputation
Rate the quality of this post and help johnt671 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnt671 is offline   Reply With Quote
Old 07-09-2006, 09:06 AM   #2
johnt671
Happy Re: 92 Sl1 four way flasher problem
Found the problem. I feel victim to the redundant fuse trick. I checked the fuse in the interior of the car and found it was good, and assumed it was a the switch. Turned out that the fuse under the hood was blown.
Flasher Module nhlkent11 Aura General 4 05-22-2009 08:29 PM
LED Flasher? oceanjoe89 S-Series Mods 10 09-09-2008 12:06 PM
four way flasher button bob3434dog Vue General 2 03-27-2007 12:30 AM
4 way flasher button kayaksonvue Vue General 2 09-03-2004 02:51 AM
flasher for DRL? ptolbert Miscellaneous Tech 8 06-03-2002 01:22 AM
