Old 04-26-2010, 09:52 PM   #1
cfg83
cfg83 is on a distinguished road
cfg83's Avatar
Default Where's the flasher relay clicker thingy?
Hello -
Maybe the answer is obvious, but I expected to find the turn-signal flasher control relay in the fuse box. Since I can hear it, I guess that means it's somewhere in the console. Is it under the plastic that covers the steering wheel?
Thanks,
CarloSW2
Add to cfg83's Reputation
Rate the quality of this post and help cfg83 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cfg83 is offline   Reply With Quote
Old 04-26-2010, 10:07 PM   #2
Default Re: Where's the flasher relay clicker thingy?
Year helps It is on the BACK Side of the I/P Panel lower left(towards front of car) side. It is a rather sophisticated unit.
Old 04-27-2010, 08:12 AM   #3
cfg83
cfg83's Avatar
OldNuc -
Oops, sorry about that. It's a 1999 SW2.
CarloSW2
Old 04-27-2010, 09:55 AM   #4
Its just next to the chime module which is in the lower center, towards the front.
Old 04-27-2010, 10:32 AM   #5
cfg83
cfg83's Avatar
OldNuc -
Thanks!
The reason I ask is that I am researching LED turn signals. But I don't want the signals to flash faster as a function of the reduced amp load.
Once I see it live, I am going to see if any of these flasher units can be swapped in :
http://www.superbrightleds.com/cgi-b...2Fflashers.htm
I won't do do an LED swap if it flashes too fast.
CarloSW2
Old 04-27-2010, 10:37 AM   #6
No, it can not. The Saturn unit is different. Do an advanced search for rapid flashing in the tech and mods section and you will find the instructions on how to change a couple of resistors in the factory flasher to slow it down. IIRC Low Saturn provided the original info.
If you can not find it I may have it in the file.
LED conversion: what flasher to use? meribona S-Series Mods 6 06-29-2016 05:11 AM
LED Flasher? oceanjoe89 S-Series Mods 10 09-09-2008 12:06 PM
Remote clicker not working after new battery installed - any ideas? tsenior S-Series General 4 05-06-2008 11:11 AM
Turn Signal Clicker OllieSC Mods and Performance 2 08-20-2002 07:44 AM
flasher for DRL? ptolbert Miscellaneous Tech 8 06-03-2002 01:22 AM
