Old 06-22-2020, 07:30 PM   #1
C152
C152 is on a distinguished road
C152's Avatar
2008 Astra XE
2008 Astra XR
Default No sound from radio
Hello all,
Please help. There is no sound coming from the sound system. Radio or CD, it doesn't make a difference. I even tried to access the board computer by holding the button for 5 seconds. No beep, either. Any suggestions?
Kind Regards,
C152
2008 Saturn 5dr XE (Opelized) Astra
2008 Saturn 3dr XR (to be Opelized)
C152 is offline   Reply With Quote
Old 06-23-2020, 06:36 AM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: No sound from radio
If the radio powers up, they are likely good, but check fuses 35 and 36 under the hood. Disconnect/reconnect the battery to reset the radio electronics. If none of that helps, the amplifier inside the radio is probably gone bad.
It's hard to imagine all of the speakers are blown but you could check them for continuity.
Old 06-23-2020, 06:48 AM   #3
imaddicted2u
2008 AURA XE
I found a radio pic that shows what looks like a 15 amp fuse in the back of the head unit.
Old 06-23-2020, 06:22 PM   #4
C152
C152's Avatar
2008 Astra XE
2008 Astra XR
Hi imaddicted2u,
Thanks, but magically the radio works normally now. Apparently, something similar happened during the winter. Don't know what to think.
Kind Regards,
C152
Old 06-23-2020, 07:02 PM   #5
imaddicted2u
2008 AURA XE
Electronics is not an exact science...lol
I read some stuff on fuse contact corrosion causing flaky problems. Maybe try cleaning them up.
Never seen a radio with a cooling duct before...I guess that's what the hole in the back of it is for. I wonder if it somehow ties into your troubles.
Duct:
https://www.gmpartsgiant.com/parts/g...6155ec90b848f7
Cap:
https://www.gmpartsgiant.com/parts/g...2f6ce22c49ab02
Old 06-23-2020, 10:19 PM   #6
C152
C152's Avatar
2008 Astra XE
2008 Astra XR
You could be right, it has been very hot these past few days.
Kind Regards,
C152
No sound from radio picaman Ion General 8 08-31-2014 10:54 AM
no sound from radio butters122706 L-Series Tech 0 01-13-2013 09:18 AM
VUE Radio-Not getting sound LuvMyVue04 Vue Tech 6 11-12-2006 01:45 PM
Help With '03 ION Radio - No Sound Jeremy4152 Ion Tech 3 09-27-2005 03:51 AM
Radio POP sound Plastic Gravity Miscellaneous Tech 1 10-26-2001 03:11 AM
