Old 05-28-2006, 07:32 PM   #1
1stSaturnowner
1stSaturnowner is on a distinguished road
1stSaturnowner's Avatar
2001 L-Series 2.2L Sedan
Default Bcm
I was told by the service writer last week that my BCM stored a code:U1000! He also told me that it was not possible to scan the BCM for other codes, because they would be erased after it was stored. Well, I have the old one. It died last week and I had to have it replaced. So I had it did, but I feel that I need to know what caused it to die. If more info is needed, go to this site:http://www.saturnfans.com/forums/sho...314#post835314
Thanks,
D.J.
Add to 1stSaturnowner's Reputation
Rate the quality of this post and help 1stSaturnowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1stSaturnowner is offline   Reply With Quote
Old 05-31-2006, 04:11 AM   #2
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Default Re: Bcm
I am going to go out on a limb, and say that one code it threw was B3033 Security System Indicates Tamper.
When it sees this code, it cuts fuel to the engine. It is USUALLY caused by an internal glitch inside the BCM, but can also be caused by a bad passlock sensor in your ignition housing. Sorry I cant tell you something more encouraging about its failure, but they arent very good.
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-31-2006, 08:48 AM   #3
1stSaturnowner
Default Re: Bcm
Thank you, Bigdaddy94sc2 for going out on a limb!
Is it still possible to read a BCM after it has stored a U1000? I want to scan it. However, I am not what scanner to use. Or if any scanner out there will read it. Would you know?
Old 05-31-2006, 01:37 PM   #4
Bigdaddy94sc2
2006 ION-2 Sedan
Default Re: Bcm
Once it is unhooked from the car, codes are lost. Sorry. It is possible to read after the u1000, but not from a universal scanner. More than likely, you will need a tech2 to pull the GM specific codes (b2xxx or B3xxx). Hope it helps!
Old 05-31-2006, 04:29 PM   #5
1stSaturnowner
Default Re: Bcm
Tech 2, well it would help if I had one. However, thanks BigDaddy94sc2.
Could this be another BCM Al10453 L-Series Tech 6 07-17-2008 10:24 AM
Is it the BCM or something else? birdieluvr76 Vue Tech 2 04-16-2007 02:08 PM
Bcm? remedys S-Series Mods 3 07-06-2006 08:11 PM
What does the BCM do, exactly? kpatz General Saturn Discussion 4 03-21-2006 03:26 AM
BCM went out... VUEnumber1 Vue General 6 08-22-2005 04:09 PM
