Old 12-08-2018, 06:30 PM   #1
ampecsu
ampecsu will become famous soon enoughampecsu will become famous soon enough
Default Reversed jumper cables! SMOKE
1995 Saturn SL2
So I had a friend give me a jump after leaving my lights on and we placed the cables on wrong on his car....(not clearly marked and he said he was sure...)
Smoke was coming from the belt side of the car but we could tell exactly form where.
Radio would not come on anymore and a day later the battery light started to be on.
Few days later my car died on the freeway and I had to pull over and get a jump (2) to get home...
Is the alternator dead? Is it possible that just a wire needs to be replaced? Where could the smoke have originated from exactly? Is a fuse at play here?
THANKS
ampecsu is offline   Reply With Quote
Old 12-08-2018, 08:09 PM   #2
Default Re: Reversed jumper cables! SMOKE
The battery light being on is a strong indicator that the alternator is dead, but could just mean the fuse-able link between the starter and alternator fried (line goes battery->starter->alternator).
Hopefully the rest of the issue's are just blown fuse's, check the under-hood fuse box near the battery first then the interior one. No hidden fuse's like some cars have and they're clearly properly marked unlike junk Ford's. If you have a multimeter they're easy to check, just probe the test points on top of the fuse for connectivity (might work with a test light too, but I believe that'll just say there's power to/from the fuse not that each point is connected).
Old 12-08-2018, 11:00 PM   #3
ampecsu
thanks i'll check it out
Old 12-09-2018, 09:59 AM   #4
onlinebiker
onlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to all
There was something to be said for a 1971 Triumph Bonneville.
The entire electrical schematic would fit on a matchbook.....
Currently owned
96 SC2 Manual
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M (2 cars)
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 12-09-2018, 12:39 PM   #5
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Lucas, Lord of Darkness had mercy on that bike?
Goggles Pisano is offline   Reply With Quote
Old 12-09-2018, 03:02 PM   #6
toggenburg
toggenburg's Avatar
^^^ Best read Revelation 20: verse 10 to see the true and final outcome.
Tags
alternator, battery, reversed jumper cables, smoking
Car starts when you jump start but when you remove jumper cables it will die vikasevan S-Series Tech 13 02-17-2017 11:07 PM
I melted the cables and wisps of smoke had me panicked djsted Ion Tech 2 12-17-2015 03:53 AM
Reversed Jumper Cables - 2000 Saturn SL2 Automatic dylank S-Series Tech 40 03-03-2015 06:48 PM
Jumper cables reversed, white smoke, no start, HEEEELP Magilla S-Series Tech 41 06-14-2013 08:52 PM
OBD II with jumper wire? Bflener L-Series Tech 4 08-24-2012 09:39 AM
