Old 02-15-2017, 10:29 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Default Car starts when you jump start but when you remove jumper cables it will die
1999 saturn sc2 with 150k miles and manual transmission.
Car does not start so when we jump start it starts but it will die when we remove cables ...what does it mean battery or alternator? or something else?
vikasevan is offline   Reply With Quote
Old 02-15-2017, 10:41 PM   #2
toggenburg
toggenburg's Avatar
Default Re: Car starts when you jump start but when you remove jumper cables it will die
Well, start with the basics.
Have you used a battery charger on it?
Using a volt meter,
What voltage is the battery with engine off, should be at lease 12.5 vdc.
History on the battery and alternator?
Forget measuring voltage on the battery if you still have jumpers attached, you will just get the other car's battery boost and probably read 14 vdc
Chances are it is the alternator. Sounds like it just doesn't have enough left in it to produce enough voltage to keep it all running.
You can run all day long with the battery removed from a car, if the alternator is good.
Old 02-15-2017, 11:53 PM   #3
billysvue
YOU're aware that the batt acts as a V sink for the alt and ( if missing) will allow V surge to impact( potentially damage) the electronics in the car?
OP has a crap battery, alt or both.
How old is the battery, OP?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 02-16-2017, 12:31 AM   #4
Running without the battery connected is relying on the MAX voltage control section of the alternator voltage regulator and this is not an overly reliable feature of the regulator. Rapid electronics failure is a real risk. You have at a minimum of a stone dead battery and probably a dead alternator to match. Do not just replace the battery ant think all is just fine now. Pull battery and have it tested and if it is bad then remove alternator and have it tested. At this point it is very easy to get into a loop alternately replacing one and then the other until you finally decide to replace both at the same time.
Old 02-16-2017, 09:11 AM   #5
toggenburg
toggenburg's Avatar
My own quote "You can run all day long with the battery removed from a car, if the alternator is good", is incorrect for modern computerized cars. I got carried away on an edit. Billysvue and OldNuc are correct.
Old 02-16-2017, 10:08 AM   #6
billysvue
Back in the day of points ignition and no computer sensors, it was a good test for alt function.
Computers screwed everything up
'17 Suby Forester
Old 02-16-2017, 10:28 AM   #7
Unfortunately you will get away with that test often enough to give the illusion of acceptable very low risk performance. It is recommended by many people who should know better. A failure to regulate without the battery usually ends up sending a modern car to the junk yard.
Old 02-16-2017, 03:40 PM   #8
underthehood
underthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the roughunderthehood is a jewel in the rough
underthehood's Avatar
2004 VUE 2.2L
It was not a good test even in the "old days". Prior to alternators it was "OK" but once alternators came on the scene it was a baaaaaad move. I was taught this going back to my days in the GM training tech center back in the 60's when alternators were still pretty "new". The systems rely on the battery to even out the pulses from a rectified AC system. It acts as a capacitor. Doing it even back then blew out radios, gauges and so on.
2006 Toyota Highlander (rare 4 cyl AWD)
2001 Toyota Highlander V6 AWD creampuff
Daughter got her own! 2005 Lexus ES330 Dream Ride
underthehood is offline   Reply With Quote
Old 02-16-2017, 03:47 PM   #9
There are many reasons why it is a bad idea and only a very few, if any, that are good ideas.
The original idea that it was OK to do came from the original Chrysler cross country drive without a battery, ran on the alternator only.
Old 02-16-2017, 05:15 PM   #10
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
Does it do that if you bench charge the battery first? The car should run for some time without alternator output.
-Robert
Old 02-16-2017, 08:38 PM   #11
billr
You are kind of comparing "apples to oranges" there. Running with a battery, but no alt, is considerably different than running with an alt and no battery. Running with only a battery should be no risk at all; no possibility of over-voltages.
Old 02-17-2017, 10:42 PM   #12
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
since it starts and runs with jumper cables only to me his ALT and bad and his battery is currently low enough tto prevent running. and If its been low long enough the battery will never fully recover......its capacity reduced.
Old 02-17-2017, 10:46 PM   #13
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
so if I a buy a new battery with full charge ...will it make it about 30 miles ?
Old 02-17-2017, 11:07 PM   #14
RobertGary1
Don't wast your money on a battery until you test it. It could just be dead because it's not charging.
-Robert
Reversed Jumper Cables - 2000 Saturn SL2 Automatic dylank S-Series Tech 40 03-03-2015 06:48 PM
Jumper cables reversed, white smoke, no start, HEEEELP Magilla S-Series Tech 41 06-14-2013 08:52 PM
05 ion, can't remove shift cables from trans. shemparelli Ion Tech 2 03-08-2009 09:16 PM
how do you remove shifter cables? rc1488 S-Series Tech 16 01-07-2008 12:54 PM
How to remove the shifter cables from a 5 speed manual saturn turbobuick33 S-Series General 1 02-06-2006 12:56 AM
