Old 08-21-2007, 12:19 AM   #1
RedVision_350
RedVision_350 is on a distinguished road
Default Odd idling
I drive a 1994 SOHC 1.9L SL and I've been having an issue in which I think I have an inkling as to what's causing it, but I'm not sure, so here I am! When I am stopped (Like at a light), the engine will start idling high to about 1500rpms and then drops below 1000rpms. Then the check engine light comes on. This happens EVERY time it is hot outside or excessively humid. In mornings and evenings this doesn't happen, unless it's really humid out. I think it might be the O2 sensor, since hot air expands and maybe it throws it off?
RedVision_350 is offline   Reply With Quote
Old 08-21-2007, 01:01 AM   #2
Default Re: Odd idling
1-Engine coolant temperature sensor; How-to Tips library's first two posts.
2-Rap the throttle position sensor on the side of the throttle body with a screwdriver handle, if the idle speed changes the tps is faulty.
3-Clean the throttle body with carb cleaner if it hasn't been done lately.
4-The O2 sensor is more expensive to replace than performing all the above first and not likely to cause the erratic idling as mich as it would affect the engine running altogether.
Old 08-21-2007, 10:02 AM   #3
RedVision_350
Ok, awesome. I'll give those a shot. Thanks!
Idling Issues outlook33 Outlook General 4 03-07-2008 02:28 PM
Odd problem with the SL1 (and odd way of repairing it)... Asterixx S-Series General 3 02-22-2008 08:49 AM
Rough Idling and Temp acting odd wittmc S-Series Tech 9 02-02-2008 03:12 AM
idling out of control clintdilley L-Series Tech 2 09-09-2005 10:11 PM
Idling Red94sc2 S-Series General 4 02-06-2004 11:19 AM
