Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Red Line
Old 08-13-2022, 08:53 AM   #1
Rebuilding
Rebuilding is on a distinguished road
Default Automatic door lock issue
Working on my door lock system and have a pretty odd issue going on
Driver side door un/lock button does not work to unlock nor lock the door
Passenger side door un/lock button locks the doors when I push it down as it should, it doesn't unlock when I push the button up. But it will unlock if I push the lock button 3 times quickly
The remote does not work to unlock, lock, nor pop the trunk
I have replaced the fuse and confirmed that the relay has not gone bad.
It seems to me that the issue might be wiring at this point to the door lock buttons, but wanted to see if anyone had additional insights on what to check next?
Rebuilding is offline   Reply With Quote
Old 08-18-2022, 12:35 PM   #2
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
Default Re: Automatic door lock issue
Lock buttons can go bad. I replaced mine last year due to wonkiness in damp weather. Turned out there was corrosion inside the switch.
JefferyC is offline   Reply With Quote
SC2 - Automatic Door Lock Problem RichSC2 S-Series Tech 4 03-30-2014 10:56 PM
What could be wrong with my drivers side rear automatic door lock? 2002SaturnMan S-Series Tech 7 09-01-2013 02:23 PM
PLEASE HELP - 2002 SL1 rear automatic door lock not working 2002SaturnMan S-Series Tech 1 08-09-2013 06:26 AM
Automatic door lock/unlock 2008Vuer 2008 Vue 2 03-31-2013 09:10 AM
L automatic front and rear door lock actuators IceMan2 L-Series Tech 0 07-25-2003 10:20 PM
