Old 07-02-2022, 03:47 PM   #1
brew9821
brew9821 is on a distinguished road
Dizzy 2004 Vue throwing codes P0325 & P0453
Just purchased a used 04 Saturn Vue
I knew it had a check engine light and the battery light is on
Itís throwing Codes P0325 and P0453
Could anyone help me to as what they are and to go about repairing them?
Itís a V6 AWD. 251k miles. No loss of power, no sounds other than the belt squealing
brew9821 is offline   Reply With Quote
Old 07-02-2022, 08:36 PM   #2
Default Re: 2004 Vue throwing codes P0325 & P0453
Search Vue threads for general problems so you have some background info. The battery light may be; charging system related to serpentine drive belt, worn belt tensioner, alternator failing, wiring including battery cables. Standby battery voltage around 12.5vdc, idle rpm around 14.5vdc. The battery should be load tested from any auto store selling car batteries (Autozone, Advance Auto, NAPA, Sears, etc) to rule out a failing battery.
P0325 SATURN Code - Knock Sensor Circuit Bank 1
One site among many explains it; https://www.engine-codes.com/p0325_saturn.html
P0453 SATURN Code - Fuel Tank Pressure Sensor Circuit High Voltage
One site among many explains it; https://www.autocodes.com/p0453_saturn.html
Search in Vue threads for these two error codes and any solutions.
Old 07-04-2022, 10:52 PM   #3
LolaAnnGram
LolaAnnGram will become famous soon enough
What Does the P0325 Code Stand For? Diagnostic trouble code (DTC) P0325 stands for Knock Sensor Malfunction (Sensor 1, Bank 1). The code indicates your car's primary computer, which is often referred to as the powertrain control module (PCM), perceives a problem with the knock sensor or its circuit
A P0453 code means that a reading from the engine's evaporative pressure sensor is higher than normal, indicating changes in pressure that are out of factory specification.
See if Grumpy will help you - he's the guru that knew exactly what was wrong with my car based on dumb blonde trying to explain. Now it runs PERFECTLY!
LolaAnnGram is offline   Reply With Quote
Old 07-05-2022, 04:03 AM   #4
LolaAnnGram
He will probably respond to your thread but if not, I suggest you look up "FarTooGrumpy".....he's a master mechanic
Old 07-07-2022, 02:00 PM   #5
SL2 Ride
SL2 Ride is a jewel in the roughSL2 Ride is a jewel in the roughSL2 Ride is a jewel in the roughSL2 Ride is a jewel in the rough
2005 ION-3 Sedan
fdryer already did, and you'll get a very similar expert response from him everytime.
SL2 Ride is offline   Reply With Quote
codes, repair, vue 04
throwing codes ! jaysan Vue General 6 02-25-2015 10:57 AM
AC failed, and now codes P1283, P0453 dieseljeepguy L-Series Tech 11 12-14-2014 06:59 PM
Check Engine light codes P0453 P0455 P0506 Veo-VUE Vue Tech 2 05-14-2010 01:20 AM
97 sc2 throwing codes red87tll S-Series Tech 1 08-03-2007 09:32 PM
Throwing codes 23 35 45 JS593 S-Series General 9 01-05-2006 12:11 AM
