Old 10-12-2018, 06:55 AM   #1
Waiex191
Waiex191's Avatar
Default Poor heat from the floor vents
When I bought my SL2 new back in '99, there was one thing that was better on my old Dodge Omni. The Omni had awesome heat on the floor - you could feel it on your feet. Today I drove my '98 SL2 for the first time in near freezing temps. It was as good on my feet as the Omni. The '99 has plenty of heat, I am thinking there is an air diverter problem. My search attempt found a lot of Vue info, but no S Series. Anybody have experience working on the vent system that would help explain this?
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-12-2018, 10:11 AM   #2
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Default Re: Poor heat from the floor vents
Does the recirc work? I dont know if that has anything to do with it, but it may. According to my 1995 owners manual it is supposed to have the max heat at the feet too.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-12-2018, 10:25 AM   #3
onlinebiker
onlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of lightonlinebiker is a glorious beacon of light
What is your temperature gauge reading?
It should be about 1/3 of the way up, between 1/4 and 1/2.
The gauges are amazingly consistent. I have yet to see one that reads wrong.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
3 96 SC2
Old 10-12-2018, 10:46 AM   #4
Waiex191
Waiex191's Avatar
Recirc works. Temperature is above 1/4 both with the new thermostat after rebuild and the old one as it came from the factory. There is plenty of heat, just not on the feet.
I drove the '98 in today without recirc, but with toasty feet.
Bryan Cotton
Old 10-12-2018, 12:45 PM   #5
Waiex191, can you verify cooling system temps with a reader, hand held infrared temperature probe or thermometer inserted into the coolant container? Once system temps are confirmed above 190F, you might have to examine the hvac controls and hvac box. For whatever reason, I'm unable to upload drawings. Perhaps later.
Old 10-12-2018, 01:42 PM   #6
Here are some drawings.
Old 10-12-2018, 02:23 PM   #7
Look up high on the left side of the HVAC box and watch the linkage as you move the slider from far left to right. Watch the damper arm on the damper closest to the rear of the car. Check that the carpet has not managed top block the flor outlets which it can do easily.
Old 10-18-2018, 07:02 AM   #8
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
The higher the gauge the better the heat inside cabin. If your thermostat is stuck at 1/4 your thermostat is an issue I recommend replacing with
So, what does the manufacturer print on the box? 188F or 195F or 212F, there is no standard established by ASME, ANSI, SAE, or some Federal Bureaucracy so they tend to drift around based on the phase of the moon and/or the prevailing wind. The STANT is at least marked for cartridge rating which helps. It is also very fine print and not on the box.
I RECOMMEND PICKING UP THE 188F FOR YOUR vehicle 212 f would be to high for summer ppl with higher ones will overheat in summer heat may be find in winter but for a good all around 188f has done me good here in texas 110 weather . My gauge goes about between half and 3/4. Then you should hear the fan kick in.
Also Since using the stant 188 f Ive noticed less gas out the tailpipe Im noticed a big improvement on mpg. So more saving in fuel cost.
If it sits at quauter way this means your thermostat opens at a lower rating .
S-series spec for thermostat cap pressue 190 13-20 psi
You need to get the one at advance auto
Cooling Capacity, Qts. 7
Radiator Cap Relief Pressure, Lbs. 13-20
Thermo. Opening Temp. Deg. F 190
Run what your engine specs say 190 opening temp for thermostat
If you run lower that the engine design. It will run rich cause more carbon inside your engine and it will be hard on your catalytic convertor . It makes the cat do more work .
The thermal element in the STANT 14279 and the spring compression together set the initial opening point at 87C(188.6F) and this is the point of minimum fluid flow. At about 195F(90.5C) the flow has reached maximum and the bypass valve, on the other end of the thermostat, has just closed. At 212F(100C) the thermostat element has reached maximum extension.
These conditions meet the published OEM design specifications for the Saturn thermostat.
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 10-18-2018, 11:01 AM   #9
RobertGary1
I had the same. Look at the side of the air box to the right of the drivers feet and you will see the sheath for the temperature selector. As you move the selector left and right the cables moves in the sheath. If that sheath breaks away from its flimsy plastic mount it will move in and out greatly reducing the travel of the temperature selector. I drilled a hole on the airbox mount and zip tied mine back on and now after skiing jn Tahoe I have heat.
-Robert
Old 10-30-2018, 09:32 PM   #10
Keblar
Keblar is on a distinguished road
Are the S-Series vents Vacuum actuated or mechanical? I feel like the flow on various settings isn't as sharp on mine as has been in early years, like vent doors aren't totally sealing. Occasionally there's a range in the dial where I can hear the doors sort of flapping/cycling in 1 or 2 second intervals. I was thinking it was just the dial managing to be in between settings, but could also be debris, or poor actuation.
Could be similar to your issues. I just sort of put up with it, but this will also be the 1st winter since I solved my manifold coolant leak, so if it's still a problem maybe I'll try to sort it out.
2002 SL2 ~300k Miles
Add to Keblar's Reputation
Rate the quality of this post and help Keblar reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keblar is offline   Reply With Quote
2002 SL2, not much heat at the vents toggenburg S-Series General 10 12-29-2017 09:01 PM
front heat vents blowing good on one side but not other? sc2 saturn S-Series Tech 9 02-25-2016 11:40 PM
2004 Ion AC Blows out Defrost and floor but NOT vents pelletman Ion Tech 2 05-09-2015 01:15 PM
Floor heat vents no worky. DavidBo Vue Tech 6 01-15-2015 03:27 PM
Hot Floor Vents!!!! Sad Outlook Outlook General 12 11-11-2007 11:53 AM
