Old 07-05-2018, 10:32 PM   #321
Default Re: 1996SL11.9L's 2002 SL1
An auto trans DOHC using ethanol gas will not break 30mpg except on the interstate at a steady cruise speed.
Old 07-06-2018, 12:43 AM   #322
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Don't use the acetone to get better milage. With driving condition and temp and weather changes it will be hard to prove. I just use it as a system cleaner and moisture absorber. Anything else acetone may do is secondary.
Old 07-10-2018, 04:46 PM   #323
1996SL11.9L
2002 SL1
Since I cleaned the water injection nozzle I went through a gallon in 200 miles.
Old 07-10-2018, 09:56 PM   #324
That will keep the inside of the combustion chamber squeaky clean.
Old 07-10-2018, 10:26 PM   #325
1996SL11.9L
2002 SL1
That I can attest to. All the epoxy glazing from running veggy oil in it two years ago with the the saturns cold arse combustion temps is gone. Cylinders 3 and 4 have aluminum piston tops with very minor carbon in the center of those two Pistons. I was so mad when that happened.
PS. I don't even know it's there since I replaced the ignition wires. That cylinder number 4 ignition wire and been a problem for a long time. It took the cam sensor code to make me realize it.
Old 10-19-2018, 10:49 PM   #326
1996SL11.9L
2002 SL1
So in February I installed this desulfation device on my Saturn. I remember my MidTronics battery tester testing it at 350cca. But it was starting the car in the dead of winter and barely passed the load test.
I get rewards at work and have or had six 50 dollar autozone gift cards. So I bought a battery from them. I removed and tested my old one and had 515cca. I still think something is wrong with it. Though. And I also need to do the parasitic load test to make sure I'm below 40ma. It sat a day or so and my charger said the old battery was at 70% charge. (12.3v)
Old 10-20-2018, 09:48 AM   #327
The generic car battery is designed to just start the car, it is not designed for long term slow discharge loads or to be maintained in a less that fully charged state. Most car applications in real life end up maintaining the battery at an average start of charge of less than 100%. This markedly shortens battery service life. The CCA calculation is a back door measurement of the battery internal resistance which increases with battery age and the rate of increase is reduced or practically eliminated by using a good quality maintainer to keep the battery at 100%.
There is a growing trend to use the new combination starting and deep cycle batteries in the latest heavily computerized vehicles.
Old 10-20-2018, 10:02 AM   #328
1996SL11.9L
2002 SL1
I drive the car 62 miles a day for work. It should be pressed up at the end of every work day with 14-14.5v pushing into the battery.
My Cummins has 2 expensive group 27 batteries. I usually plug that into my 8a deltran charger every few weeks if I don't drive it. I keep a volt meter in the cig lighter and when I see 12.5v on it, it's time to charge it or drive it.
Old 10-20-2018, 11:35 AM   #329
1996SL11.9L
2002 SL1
Car sat overnight since 10pm and battery post voltage is 12.7 temps last night were in the low 40's. It's all good IMO. I'm not going to do the parasitic drain test seeing this.
Old 10-20-2018, 11:46 AM   #330
That sounds like it is OK. whatever drain there is and whatever error is in the DVM are insignificant.
Starting batteries do have a short service life almost by design so plan on periodic replacement.
Old 10-20-2018, 01:30 PM   #331
1996SL11.9L
2002 SL1
I just mounted the desulfator on my Cummins.
Time will tell.
Old 10-27-2018, 05:51 PM   #332
1996SL11.9L
2002 SL1
Since I started load cycling the battery I removed from the satty my Schumacher battery charger has stopped going into desulfation mode trying to charge it.
I'm a firm believer that batteries should be load cycled on a regular occasion. The Saturn has a relatively easy load on the battery.
My truck on the other hand has intake heaters along with a 3.5hp starter running on 12v. So it's an impressive amp draw. All though now with the new starter the diesel lights off in around 1 second.
The core on the Saturn battery is 18 dollars. I'll return it eventually. I'm too busy playing now.
Old 10-28-2018, 10:44 AM   #333
Signmaster
I've never used a battery maintainer or such device in the Saturn, and have had amazing battery life out of an Autozone red battery. We get a lot more of the hot temps than the cold, but do see teens and single digits some years. This battery has also been through a number of periods with sitting for at least a couple months at a time, and at one point probably close to 6 months.
This thing fires so easy that the battery just doesn't take much abuse. I can't complain when it finally dies, but have to wonder if it's just the luck of the draw. I have no accessory stuff other than aftermarket radio, and don't put any loads on the battery other than starting.
Old 01-05-2019, 02:16 AM   #334
1996SL11.9L
2002 SL1
I’ve got the battery up to 500cca.
On another note I got 43mpg tank average driving to BWI airport and back. 333 miles total. 62 miles was for my last day of work first time I took it on the highway since I bought it.
I plan on pulling the heat range 6 EK plugs I’ve been running. It’s time for an inspection. they have at least 40k miles on them now.
My timing cover leak is getting worse. It’s time to pull it, inspect the timing chain and reseal it.
Old 01-05-2019, 09:43 AM   #335
I was thinking the same thing, time to pull the EKs that I installed back when we started this test and have not touched them. Still running just fine as far as I can tell.
For the timing cover this stuff works very well as long as you give it time to set before assembly and it gives you hours of fiddling time and still seals oil tight. Permatex 85420.
Old 01-13-2019, 10:20 PM   #336
1996SL11.9L
2002 SL1
It also appears I have the dreaded trunk leak. Rear passenger trunk cavity has water in it.
Old 01-23-2019, 04:01 PM   #337
1996SL11.9L
2002 SL1
So I’ve now got the dreaded antifreeze leak weeping between the head and the block at number 4 cylinder. Just like my old 96. Soon it will be time to pull the head.
My brother and I have a spare head off a 2001. I’ll most likely have it gone over and do the intake valve mod and signs groove like I did on my 96 a bunch of years ago.
I already tried the copper stop leak. It lasted a half year or so. I guess it’s time to start thinking about replacing the head gasket.
File Type: jpg 9F6B65D0-8B29-49AC-99A4-22525AC9BACF.jpg (127.4 KB, 4 views)
Old 01-23-2019, 07:04 PM   #338
Probably true as stop leak only works once.
Old 01-26-2019, 08:31 PM   #339
1996SL11.9L
2002 SL1
This is cylinder 3. Like I mentioned in the “Not Your Typical Sparkplug Question” where I placed two other pictures the gap is now at .050. It looks good at 40,000 plus miles. Gap erosion appears to be less than .002per 10,000 miles.
File Type: jpg 4BEE8286-6268-4570-8035-7B8ED6B7F32D.jpg (77.8 KB, 3 views)
Old 01-27-2019, 09:09 AM   #340
Signmaster
Still looking good. I wouldn't be surprised if you can get 100k plus out of them if they are burning that clean.
2002 sc2 b.c.m. piperpilot S-Series Tech 2 11-12-2014 09:34 PM
2002 sl 1 Dee631 S-Series Tech 1 11-04-2014 05:36 PM
2002 SC2/Metra 70-2002 stereo harness issue Kai S-Series Tech 4 12-14-2008 03:41 PM
2002 SL1 Help Please reddragonflys20 S-Series Tech 9 11-21-2006 04:26 PM
2002 Sc2 Sps mle S-Series General 1 07-02-2005 07:33 PM
