Old 10-19-2018, 08:49 PM   #1
Packard
Packard is a jewel in the roughPackard is a jewel in the roughPackard is a jewel in the rough
1995
Default No Engine light code 26 plz help?
CODE 26 But my check engine light is off . Does this mean problem is fixed. When I run paperclip code 26 is there but I dont have light . What does this mean? Does this mean it recovered and Im safe to inspections ? If my light is off am I in the clear? Ive already replaced the solenoid for this 26 and it fixed it last time .If my light is off am i ok when I can paper clip a code but then the light is off .
Add to Packard's Reputation
Rate the quality of this post and help Packard reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Packard is offline   Reply With Quote
Old 10-19-2018, 10:02 PM   #2
Default Re: No Engine light code 26 plz help?
Unfortunately, that "code 26" is so vague as to be near-useless. It refers to a problem in the PCM outputs, and there are eight of them. The problem could be in one, any or all. The fault could be an open circuit, a shorted circuit, or anything in between. Replacing a single component (like that solenoid) doesn't tell you much about why the 26 is set or fixed. There could be a different cause, or combination of causes, every time you turn the key on.
Is your concern emissions/safety inspection? If the CEL isn't on at time of test, I don't think it will be and issue; "flags" set don't matter.
Add to billr's Reputation
Old 10-19-2018, 10:20 PM   #3
RobertGary1
1996 SC2
For odb 2 an active code with no mil lamp is still an automatic failure. Not sure about odb1
-Robert
Service Engine light but no code Joshtheclockman S-Series Tech 12 10-10-2011 02:47 PM
Engine light, no code. bk63 Vue General 3 09-18-2010 07:28 PM
Need help with engine light code PO430 tripplegs Aura General 10 12-06-2009 06:12 PM
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
check engine light.. no code??? runerx Vue Tech 4 04-17-2006 01:17 AM
