Old 06-21-2018, 10:19 AM   #1241
Default Re: how many miles do you have on your saturn?
Wow, that car looks amazing, esp considering the miles.
How often did you change the oil?
Hard to argue with success, but the PL20195 also fits and gives you a little more capacity. It's almost 1 1/2" longer, spec comparison here
https://www.bobistheoilguy.com/forum...95_vs._PL10241
(I think the fact you are using DexCool and have been for 400k miles is going to blow Saturn Night's gasket - expect a demand for video)
Old 07-02-2018, 08:53 PM   #1242
ivan0_10
ivan0_10 is on a distinguished road
2001 SL1 218K miles
Add to ivan0_10's Reputation
Rate the quality of this post and help ivan0_10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ivan0_10 is offline   Reply With Quote
Old 07-03-2018, 11:55 AM   #1243
Eienring
Eienring is on a distinguished road
My 2001 SC1 is at around 92K, was about 45K when I bought it back in 2004. Tells you how little I drive.
Add to Eienring's Reputation
Rate the quality of this post and help Eienring reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eienring is offline   Reply With Quote
Old 09-24-2018, 03:54 PM   #1244
cwalden
cwalden is on a distinguished road
1999 SL1
My mother recently passed away and she had a 1999 Saturn SL1. It was given to me. Much to my surprise it only has 80,617 miles on it.
Add to cwalden's Reputation
Rate the quality of this post and help cwalden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cwalden is offline   Reply With Quote
Old 09-24-2018, 05:11 PM   #1245
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: how many miles do you have on your saturn?
Only 67,500 on my 1997 SL1.
1995 SL1 236,300 2005>2018
1997 SL1 67,500 21 yrs. and Legal!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
Old 09-24-2018, 07:45 PM   #1246
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
2000 Saturn SL2, I'm up to 450,600km. Owned the car since new, always on Synthetic. Oil changed every 6000 - 8000 km. Uses about 2L per OCI. Original engine, alternator, power steering pump, starter, fuel pump, transmission ( except for valve body ) rack pinion, coil packs. Items replaced other than brakes, suspension, and exhaust is: valve body, blower motor, radiator, driver inside door lock button, dash lamps, EGR, TPS, IAC, ECT Sensor, idler pulley, belt tensioner, one low beam bulb, and all wheel bearings. Of the valve body, I replaced the TCC Solenoid and Line Pressure Solenoid in the changed valve bodies. We live in Nova Scotia, rust capital of Canada. This one is heavily undercoated every year and spot undercoated every oil change. The drivers seat has a busted spring that popped a hole in the back of the seat. The bulbs all blew in the radio except one. The engine runs very quiet, listening to it you would never know it is at this mileage and age.
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-16-2018, 11:00 AM   #1247
TheNoteTaker
TheNoteTaker is a jewel in the roughTheNoteTaker is a jewel in the roughTheNoteTaker is a jewel in the rough
1996 SC2
1996 SC2 with 153k on the body and trans, just rebuilt the dual cam in it.
1996 SC2 1.9L DOHC w/auto trans. and only 136K original....It's purple :3
Add to TheNoteTaker's Reputation
Rate the quality of this post and help TheNoteTaker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheNoteTaker is offline   Reply With Quote
Old 10-16-2018, 02:09 PM   #1248
Reliabilityman
Reliabilityman is on a distinguished road
Reliabilityman's Avatar
356,000 miles, original clutch and back brakes. Clear coat is starting to peel after being in a hail storm.
1995 Saturn SL1 Owned since new
360,073 Miles Original Clutch, Back Brakes
2000 L Series Owned since new
154,000 Miles, Melted Fuse Box, Randomly Opening Trunk, Leaking AC condensate into cabin,
Add to Reliabilityman's Reputation
Rate the quality of this post and help Reliabilityman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Reliabilityman is offline   Reply With Quote
Old 03-19-2019, 07:15 AM   #1249
tomaso401
tomaso401 is on a distinguished road
2003 Vue 2.2 with 5 speed. Currently at 350k miles. Working to beat those pesky 400K guys.
2003 Saturn Vue 2.2
316,000+miles
She won't die...
Add to tomaso401's Reputation
Rate the quality of this post and help tomaso401 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tomaso401 is offline   Reply With Quote
Old 08-31-2019, 03:49 AM   #1250
S-forever
S-forever is on a distinguished road
1991 SL2
I have many Saturn S-Series, mostly in various states of storage or repair. My daily driver(97 SL2) has 339K miles on the original engine and automatic. It just picked up a vibration on a long trip(600+ miles at 70 mph) and I suspect that my front bearings and/or CV's are getting tired. She's been a super reliable car and only got me stuck once with a bad starter. I use diesel rated regular oil all the time, though I've only owned her for the last 80K miles.
Add to S-forever's Reputation
Rate the quality of this post and help S-forever reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S-forever is offline   Reply With Quote
Old 08-31-2019, 05:09 AM   #1251
Mr.Squeaky
Mr.Squeaky is on a distinguished road
1996 SL1
My 96 SL1 has 222,000 on it. When I bought it new in 96, I never thought I would be driving it for 23 years.
Original owner 96SL1 220,000 Miles
Add to Mr.Squeaky's Reputation
Rate the quality of this post and help Mr.Squeaky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mr.Squeaky is offline   Reply With Quote
Old 08-31-2019, 09:35 AM   #1252
This describes my Saturn experience exactly. The '99 has 220,000 plus. Although my kid is driving it and I had to buy myself a '98 SC2, it's still mine for now.
Add to Waiex191's Reputation
Old 08-31-2019, 11:07 AM   #1253
454cid
168K miles. I'm putting about 100 miles a day on it, getting 32.x--->34.x mpg.
1999 Chevy K3500
Add to 454cid's Reputation
Old 09-04-2019, 11:51 PM   #1254
BB99SL2
BB99SL2 is on a distinguished road
181,000 miles. 1999 SL2 automatic, bought it brand new in 11/98. Never had to change any internal engine parts! Very firm believer in checking that oil and changing it every 3000 miles. Never had a oil leak anywhere or the valve cover off. I even still got the original exhaust on! Motor wise, can not beat LLO engine! Great gas mileage and very reliable motor! ONLY wished that GM never stop production of Saturn SL2 cars.
Add to BB99SL2's Reputation
Rate the quality of this post and help BB99SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BB99SL2 is offline   Reply With Quote
Old 09-05-2019, 12:16 AM   #1255
red92xblue
red92xblue is on a distinguished road
red92xblue's Avatar
1996 SL2
200000
Add to red92xblue's Reputation
Rate the quality of this post and help red92xblue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
red92xblue is offline   Reply With Quote
Old 09-07-2019, 03:39 PM   #1256
Mad Mike
Mad Mike is on a distinguished road
1997 SC2
1997 SC2 currently 235000 miles and counting.
Recently sold my 1998 SL2 at 202000. I miss that car already.
Add to Mad Mike's Reputation
Rate the quality of this post and help Mad Mike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mad Mike is offline   Reply With Quote
Old 09-07-2019, 04:37 PM   #1257
Mr.Squeaky
1996 SL1
Hit 222,000 yesterday! Who Hoo!
Old 09-08-2019, 12:25 AM   #1258
Cheryl17851
Cheryl17851 is on a distinguished road
94 sl1. I got the car 10 years ago. The odometer stop working before that. I figured it's between
400,000 to 500,000.
Add to Cheryl17851's Reputation
Rate the quality of this post and help Cheryl17851 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheryl17851 is offline   Reply With Quote
Most miles on a Saturn SaturnManiac General Saturn Discussion 73 09-07-2019 04:33 PM
'02 SL, 104,xxx miles, going through 1qt/250 miles, 20 MPG!!! jeadra S-Series General 10 12-12-2009 05:48 PM
How many miles are on your Saturn? Arnel General Saturn Discussion 72 07-08-2003 12:55 AM
Like New 16" Chrome-Clad L-Series Wheels (4,500 miles) with tires (250 miles) UH2L Classifieds 6 07-07-2003 03:34 PM
How Many Miles on Your Saturn? ProjectSW1 General Saturn Discussion 53 06-12-2001 06:37 PM
