Old 01-08-2010, 11:38 PM   #41
MINICooperS
MINICooperS is a jewel in the roughMINICooperS is a jewel in the roughMINICooperS is a jewel in the rough
MINICooperS's Avatar
Default Re: Tire Pressures for S Series
36psi all around, rotate every 5K, 36mpg, I'm on 4th set of tires (Nitto) at 233K miles.
Add to MINICooperS's Reputation
Rate the quality of this post and help MINICooperS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MINICooperS is offline   Reply With Quote
Old 01-08-2010, 11:54 PM   #42
Derek McNelly
Derek McNelly is on a distinguished road
Derek McNelly's Avatar
I'm running mine at 44 psi, which is the max rated for the tires.
I've got a slow leak in the front left tire, so I have to check it every time I fill up. Usually top it off then as well.
Add to Derek McNelly's Reputation
Rate the quality of this post and help Derek McNelly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Derek McNelly is offline   Reply With Quote
Old 01-09-2010, 09:45 AM   #43
MikeNW
MikeNW's Avatar
1997 SL
about 34 x 4 on the highway
yes it rides a little stiffer but gets better gas mileage and I drive like Grandma anyway
"I've got a slow leak in the front left tire, so I have to check it every time I fill up" - scary, who knows when it will become a FAST leak!
I worked for AZ dept of trans, saw many roll-over accidents, many were from blow-outs or underinflated tires becoming HOT and failing.
08 Burgman 400
Add to MikeNW's Reputation
Rate the quality of this post and help MikeNW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-09-2010, 12:42 PM   #44
Derek McNelly
If I could afford new tires, trust me, I'd get 'em. It's not anywhere near as bad as it sounds. It's something like a 5 psi drop every week or so, so I just top it off when I get the chance.
Old 01-09-2010, 02:28 PM   #45
Starduster_Sat
Starduster_Sat is on a distinguished road
Starduster_Sat's Avatar
Whee! The thread lives!
Originally Posted by CND_SC1 View Post
By all accounts the Altimax HP is an excellent tire. I'm also assuming it's in a 185 or 195 width? (I don't think they make it in 175).
Assuming it's not 175, I'm still kind of surprised you'd find it "squirley" at 34/30 or 35/31.
However I would allow that my impression of Saturn's 30/26 recommendation might have been less negative if I had experienced it with a good touring or performance tire of a 185 instead of low performance 175.
What's coloring this thread is an important lesson- tire choice makes a huge difference in how your car behaves. I have the comparison of our 2 SL2s as a reference. The 97 came with the 185/65R15 Firestone Affinitys. At the time, the whole car was such a total upgrade over the Chevy Spectrum (with its pronounced bump-steer in back) that the Affinity's rubbery steering response when new was not noticed. Then I purchased the 95 used, and went through several sets of the popular Dunlop Sport A2's. I always thought the difference in handling beween the two was due to springs and shock damping. Until the A2's were discountinued by Dunlop (just as well- the last 2 sets (A2 Plus) got ear-ringing LOUD when they wore down), and the closest Dunlop available was the Signature- not a performance tire, but longer lasting. About this time, I finally went researching at Tire Rack, and found the Michelin Pilot Exalto's, 195/60R15, for the 97. Now it's the 97 that handles better. My wife's daily driver, and she is thrilled. All in tire choice.
Those in this family who autocross or road-race will tell you that tire choice can make the difference between being up front or off the back.
Also, there is another thread currently running where the owner has been going back and forth between 14" and 15" wheelsets, and duly noticed the dramatic difference in how the car behaves.
Ultimately, your needs and preferences may be different than ours. Research well...
Add to Starduster_Sat's Reputation
Rate the quality of this post and help Starduster_Sat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Starduster_Sat is offline   Reply With Quote
Old 01-09-2010, 04:41 PM   #46
S3aturnR
S3aturnR is a jewel in the roughS3aturnR is a jewel in the roughS3aturnR is a jewel in the rough
S3aturnR's Avatar
1996 SL2
1999 SL1
yes, tire choice is quite important in autocross. especially with "street" tires. if you're not running one of the 2 or 3 top tires, you're probably not winning unless there's nobody else in your class. wheel size is important, too. if you're running anything bigger than a 15" wheel on your s-series, i will beat you every time. if you're running a 17" wheel (or bigger), it won't even be close. if you can cram a 13" wheel on your car (i've tried without success) and make it work, you have the gearing advantage on your side.
as far as tire pressures; stick with what Eric says. i'm pretty sure there's some saturn engineers that call him up to ask about the s-series saturn. for auto-x racing, you generally run the lowest pressure you can that doesn't let the sidewall touch the ground. after that, you adjust for balance depending on conditions. most of the time you don't have to worry much about over heating the tire...
s3aturnr
"reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior
Add to S3aturnR's Reputation
Rate the quality of this post and help S3aturnR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S3aturnR is offline   Reply With Quote
Old 01-09-2010, 10:40 PM   #47
eRic 02sc2
eRic 02sc2's Avatar
s3aturnr
LOL! they're surprised mine is still running...
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Add to eRic 02sc2's Reputation
Rate the quality of this post and help eRic 02sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-11-2010, 04:28 PM   #48
isoOctane
isoOctane is on a distinguished road
2000 SL2
Originally Posted by eRic 02sc2 View Post
30 psi front, 26 psi rear. Saturn came up with that number after testing the OE Firestone tires.
Roads around here are littered with potholes. Would that pressure still work?
Any problem can be solved with more horsepower.
Add to isoOctane's Reputation
Rate the quality of this post and help isoOctane reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
isoOctane is offline   Reply With Quote
Old 11-11-2010, 09:47 PM   #49
bumpdraft
bumpdraft's Avatar
1998 SW2
I believe too much air will break the belts...per my dad, he runs too much air in his SW2 and has broken belts.
For highway, I ran my OE Firehawks at 30/26
My current set of Firehawks seem to do better with a few pounds more air.
Due to my negative camber, too much air makes the car follow ruts too much.
(although, finally setting the alignment and track properly sure helps the driving experience THAT'S FOR SURE!)
Add to bumpdraft's Reputation
Old 12-24-2018, 04:55 PM   #50
Ecomike
Not sure how much the tire brand matters now days, but I the largest tires stock allows by Jeep and if I go over 26 lbs front 28 lbs rear the ride gets super bumpy and over steers, almost floats the front end.
I use to run similar pressures on the Saturn SL1, but I have been running 32 on all 4 tires for 4-5 years now, as the tires look scary flat-like even at 32. I noticed today the Tire Max pressure rating is huge like 52? (maybe it was 44, I forget) But we never had tires that could go over 32 psi back in the 1970s....
Add to Ecomike's Reputation
Rate the quality of this post and help Ecomike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-24-2018, 09:55 PM   #51
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Original tires were 185/65R15, in "S" speed rating....
35 PSI max...
My current tires are 205/60R15, in "H" speed rating...
51 PSI max...
I put 44 PSI in rear, 37 front, getting around 42 mpg highway...
NGK BKR6E-11 spark plugs
Tire Pressures LOANSUM Aura General 28 07-14-2009 09:26 PM
High Tire Pressures-Beware! Seasoned Aura General 27 10-11-2008 05:16 PM
Tire pressures on DIC? billwill Aura General 21 06-01-2008 02:58 AM
Proper tire pressures for Aura XR with Goodyear LS2's??? Phil Henry Aura General 35 05-04-2008 10:31 AM
Tire pressures for best fwd launch? Bill Murray Mods and Performance 6 03-29-2004 10:03 PM
