Old 12-11-2018, 04:54 PM   #81
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: Urgent! Fuel issue!
Originally Posted by Chazberry View Post
Btw - I noticed my Fuel Level shows 1/4 tank - so I guess that ECM output is working for me - not the case for the OP.
I've previously found no fuel pump run and no fuel level indication being caused by bad ECM/TCM 10A fuse or broken wire between the fuse and input to ECM at C2-15.
I suggested OP focus on this circuit a couple of times but they may have larger power wiring problems now.
I've not probed Vue ignition pack leads but have used a logic probe with success on Chevy pickup (4.3L).
https://www.harborfreight.com/catalo...q=logic+probes
I rarely visit forum but respond to private messages (PM). PM creates email to phone & please include email address with question. Avoid using Visitor Message feature ... I almost never check those.
far2grumpy is online now   Reply With Quote
Old 12-11-2018, 05:25 PM   #82
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
I assume with one of these probes connected to the ECM-side of the Coil, an LED would turn OFF when the ECM fired that Plug?
Add to Chazberry's Reputation
Old 12-11-2018, 06:28 PM   #83
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
True - blinks at crank rpm as ECM provides ground path for tested plug.
Old 12-12-2018, 03:24 PM   #84
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
Well - no blinking with one of these probes - LED just stays RED. Back to the voltage and continuity checks.
Old 12-13-2018, 01:16 PM   #85
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Have you seen this diagram?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Urgent brake issue 2000sl1blue S-Series General 5 03-08-2017 01:14 AM
terrible over heating issue. URGENT! solarcar_sc1 S-Series Tech 9 11-28-2013 04:03 PM
URGENT tensioner/serp belt issue myolbug S-Series Tech 10 01-27-2011 07:33 AM
bad wheel bearing -- urgent issue or let it go a week? my98saturn S-Series General 4 03-15-2010 11:14 AM
Fuel/starting issues...urgent!! SL1_sleeper670 S-Series Tech 8 05-02-2009 08:17 AM
