Old 12-06-2018, 05:37 PM   #1
ratwhisperer
ratwhisperer is a jewel in the roughratwhisperer is a jewel in the roughratwhisperer is a jewel in the rough
ratwhisperer's Avatar
1997 SL1
Default Parasitic Drain - electrical system
My 1997 SL1 with almost 285,000 miles on it is having an electrical problem If I leave it sitting overnight the battery is dead in the morning and I have to jump it. It drives fine once jumped, no issues.
This just started a week ago. Battery, alternator and starter test fine. No SES light. Battery is less than a year old and so is the alternator.
Cables are fine.
So my suspicion is a parasitic draw of some sort. What are the most common points of parasitic draw that these cars get? I've never had to deal with this before. Or are there any common places? If not, that's how it goes... prepared to test all the things.
Sigh. I hate electrical stuff. Any tips and tricks?
Thanks in advance as always.
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
1994 SL2 - Nelly Belle
Current:
1997 SL1 - Cinnamon - 285K
1996 SL2 - Blanca - 36K
Add to ratwhisperer's Reputation
Rate the quality of this post and help ratwhisperer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ratwhisperer is offline   Reply With Quote
Old 12-06-2018, 05:53 PM   #2
bluesl2
bluesl2's Avatar
Default Re: Parasitic Drain - electrical system
The trunk light staying on used to be an issue that would pop up once in awhile, fold the rear seat back down and take a peek.
Add to bluesl2's Reputation
Old 12-06-2018, 08:37 PM   #3
trottida
trottida's Avatar
The infamous chattering door locks will do it too. I remember on my 93 SW2 I'd lock the doors and walk away only to return latter to chattering door locks. Check your door switch.
2001 SL1 MT (423,500 km @ 10/2018)
1999 SL2 MT (267,940 km @ 10/2018)
2011 Suburban LT (116,506 km @ 10/2018)
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Add to trottida's Reputation
Old 12-07-2018, 12:55 AM   #4
GTS350
GTS350 is a jewel in the roughGTS350 is a jewel in the roughGTS350 is a jewel in the rough
1999 SC2
It only takes a few minutes to figure it out. Put a meter in series between the (+) terminal on the battery and its cable and start pulling fuses 1 by 1 and look for the change on the meter.
1999 Saturn SC2 (automatic) 23,000 orig miles (9/10/16)
1996 BMW E36
1971 Holden Monaro GTS 350
1908 Buick Model 10
Add to GTS350's Reputation
Rate the quality of this post and help GTS350 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GTS350 is offline   Reply With Quote
Old 12-07-2018, 02:49 PM   #5
ratwhisperer
1997 SL1
Oh yeah I know how to diagnose it I just was wondering if there was any common hot spots I should check for. The trunk light could be the culprit. I will check that first. As for the chattering door locks. This car is the absolute base model, doesn't have power anything, doesn't even have power steering!
Thanks all for your responses!
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
Current:
Old 12-08-2018, 09:28 AM   #6
2NDSOUT
2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice
2NDSOUT's Avatar
1994 SL2
1999 SL
Just because the Battery is less then a Year Old, and Tests Fine, doesn't mean that it is Ok.
Honestly- if I was in your situation; I would take the battery back to where you bought it and swap it for a new one.
Stranger things have happened. I have had brand new batteries go bad- 6 months after I bought them, and then having to swap them out for new ones. It is very possible that your New Battery- while it may test good and be less than a year old- could very well have a bad cell in it- that right now; may not show signs of Testing bad, but is wreaking havoc on your electrical system as is shown with the Parasitic Drain. The weather is probably not helping the situation either, depending on where you may be located.
Cold Weather and a Bad Battery= Failing Battery in your car.
I would be willing to bet; that your Battery is the main culprit here.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 12-08-2018, 03:55 PM   #7
Highmile
Highmile's Avatar
Disconnect the battery and let it sit overnight then connect it and see if it will start.
Along with the other stuff, disconnect the alternator. They are famous for drains.
Highmile
'95 SL1 673k and counting
Add to Highmile's Reputation
Old 12-08-2018, 08:13 PM   #8
Bruce Rock
Bruce Rock is a jewel in the roughBruce Rock is a jewel in the roughBruce Rock is a jewel in the roughBruce Rock is a jewel in the rough
2000 SL2
2006 VUE 2.2L
For newer vehicles, where current draw can be related to time after battery is connected, I like this method:
https://www.youtube.com/watch?v=lRcj1fQcWwU
Just remember, you may get a milli volt reading when your test leads are not connected. This doesn't your meter is faulty. It is due to them acting like an antenna, picking up electromagnetic waves (radio waves) and the multi-meter amplifying and displaying them.
Add to Bruce Rock's Reputation
Rate the quality of this post and help Bruce Rock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bruce Rock is offline   Reply With Quote
Old 12-10-2018, 02:04 PM   #9
ratwhisperer
1997 SL1
Thank you so much for everyone's help! It turned out it was the trunk light after all (thank you for that suggestion!) I don't really even use the trunk light, so I just disconnected that, and we have had no issues since! Thank you all for your help!!! You are the best!
Past:
1995 SW2 - Cynthia
2000 SW2 - Ruby
2004 Vue - Jade
1996 SL2 - Ursula
Current:
01 Saturn SL 1.9L AT - parasitic drain...??? photoashleyk24 S-Series Tech 12 12-17-2016 01:31 PM
Electrical system? Ethman S-Series Tech 1 10-25-2014 12:02 AM
Electrical System Help! banditkaine S-Series Tech 3 12-15-2008 01:21 PM
Electrical system? dreamliner77 S-Series General 10 11-15-2006 11:17 PM
Best way to drain cooling system? SRGW S-Series General 3 05-27-2006 12:18 PM
