Old 12-08-2018, 12:42 PM   #1
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Default 2006 ion p0326
Was diriving in wife’s car the other day and it’s UltraGauge alarmed for a pending P0326 code... my question is, can anything but the knock sensor trigger this code?
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
“Stock” is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 12-08-2018, 03:34 PM   #2
Default Re: 2006 ion p0326
P0326 is only for the knock sensor detecting pre detonation - an unusual combustion event associated with higher than normal compression, excessive carbon buildup raising compression, incorrect heat range spark plug, poor quality fuel. A pending code usually means the error was detected, corrected and monitoring is underway. The check engine light, presumed off, should mean everything's fine. The pending code isn't a live error.
If the check engine light is on, the error is live.
Below is a file for '05 but should be applicable for '06.
Old 12-09-2018, 05:35 PM   #3
19boneatock88
2004 ION-2 Sedan
I had no idea that it would throw the code upon detecting pre-ignition, thought it would just adjust timing and go on... then again if not or the pending code alarm id have never known it at all... both the cars are on factory original plugs and I always use cheap fuel... wifes car is regularly ran at low load(high vacuum at cruise) which can make for some carbon buildup... maybe I should get some fuel system cleaner and maybe swap the plugs out for new... I ran NGK in my Redline, do they make a decent plug for the L61 or should I try and find the original ACDelco iridium?
Jerama- WV
Old 12-09-2018, 06:04 PM   #4
Follow owner's manual guidelines on when to replace parts. As long as the check engine light remains off, the emissions system is fine. Regular spark plugs tend to wear down due to pre-existing designs left over from non EFI, non electronic ignition systems going back to carburetors and distributors. Spark plugs eroded and needed 5k mile cleaning, filing and gapping, lasting only 15k miles or so. When EFI systems and high voltage electronic ignition became standardized, exotic spark plugs made of platinum or other metals allowed plugs to last 100k miles without wear. I replaced my platinum (stock) plugs at 100k miles in my L300. They show very little signs of wear and could last another 100k miles but heat cycling may create stress in long term use so replacing them is wiser. Designs of platinum and other exotic plugs allows the tips to remain intact without wearing down but only recommended for engines designed to use them.
P0326 issue nickroa95 S-Series Tech 13 10-31-2018 01:34 PM
99 SL P0326 and P0420 BigHink66 S-Series Tech 5 10-06-2014 10:06 AM
P0326, P0404, and P0410 josteen S-Series Tech 8 12-08-2013 08:00 PM
P0326 followed me from SL1 to Ion2 ttreibel Ion Tech 15 01-04-2013 11:37 PM
p0300, p0326 and also can't shift shemparelli Ion Tech 3 11-24-2012 11:55 AM
