Old 12-06-2018, 01:14 AM   #1
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
Default Bent Rim
Hello all,
tonight I nailed a good pothole, bent my front passenger rim a little, maybe a 1/2" along a 2" stretch of it. Still holds air and no major vibrations, can I just smack it back with a large hammer? It is my winter set but the tires are real nice. Also, it broke the hubcap and the rear passenger hubcap too, so it was no small pothole.
I plan on inspecting the suspension tomorrow as well as the sub frame, as it was a good hit.
Any input on the wheel and getting it back into shape is appreciated.
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Old 12-06-2018, 09:50 AM   #2
Telyx
Telyx is on a distinguished road
2002 SL
Default Re: Bent Rim
Assuming you have steel wheels, yes, you can pound the bend out with a hammer. I had my right front get bent a couple of times hitting potholes, so I'd just take it off, lay it on the ground, then pound it until it looked even with the rest of the wheel.
RIP my 2002 SL1, totaled 9/18/2012... found its replacement (2002 SL) 9/26/12, traded it in 5/10/2018 (199,604 miles).
Add to Telyx's Reputation
Rate the quality of this post and help Telyx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Telyx is offline   Reply With Quote
Old 12-06-2018, 10:46 AM   #3
If steel you can hammer it back into shape, but I've found using anything to protect the finish means I can't smack it hard enough to do any good. Not a problem if you have a heated garage but it's hard to spray paint in less than 50f temps and have it do any good.
Old 12-06-2018, 11:40 AM   #4
cgg17
cgg17's Avatar
Thanks. Yes, I should have specified that they are steelies. I did what you suggested, and it seems fine. No vibration issues either. Just need a hubcap
Old 12-06-2018, 11:41 AM   #5
cgg17
cgg17's Avatar
I smacked them really good, took some paint off. Its my winter set so I am not concerned about rust at this point. Just glad it wasn't my alloys.
Old 12-06-2018, 11:53 AM   #6
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
I worked in a tire shop as a kid age 15-18. We used to hammer out those kind of dents in steelies all the time. Did you check the inside/other edge of the rim as well?
1997 SW2 used 12/29/2011 with 124,200 -27 mpg
2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
1994 SL1 new traded
1992 SL2 new traded for above
Add to dummo's Reputation
Old 12-06-2018, 01:59 PM   #7
So you leave the tire on and just pound it?
Add to Waiex191's Reputation
Old 12-06-2018, 04:39 PM   #8
Telyx
2002 SL
That's what I did. A 2-lb. drilling hammer or mini-sledge works great.
Old 12-06-2018, 05:18 PM   #9
I love steel rims.
Old 12-06-2018, 07:19 PM   #10
SLfun
2006 ION Red Line
A couple weeks ago I hit the edge of the old pavement where they were grading for road work. Hit so hard my wipers came on!
I have alloy rims for my snows, but they are indestructible VW alloys from the mid 90's so no problems.
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-07-2018, 11:57 AM   #11
cgg17
cgg17's Avatar
I did not! I'll pull it today and check that too.
Old 12-07-2018, 02:07 PM   #12
Originally Posted by SLfun View Post
......I have alloy rims for my snows, but they are indestructible VW alloys from the mid 90's so no problems.
That can't be possible. A co worker bought a VW Corrado with stock low profile tires (45 series). He broke all four rims in less than a year. NYC potholes. He said they were $1600 for the set.....
bent tie rod greenman Aura General 16 04-23-2011 12:11 AM
Bent ECTS. Why? facility S-Series General 7 04-13-2011 09:35 PM
Bent rim -Please help ATH Ion General 3 05-17-2009 05:50 PM
What likely bent? MacG S-Series Tech 2 02-28-2009 01:00 PM
Bent rim = Bent wallet RustyJCNC Miscellaneous Tech 10 06-26-2002 12:42 AM
