Old 12-06-2018, 12:49 AM   #1
gas3987
gas3987 is on a distinguished road
Default TAAT sprag clutch part number and where to buy
So I've done some testing to the 'ol Saturn, and I'm trying to find the correct part number for the 1st gear sprag clutch. I've come upon two, and was hoping someone could clarify it for me.
FWIW, it's a 1999 SL2, had it once not move initially during a cold start. Hasn't done it since on multiple cold occasions since. I did, however, do an overnight cold (below freezing) test and all the pressures were fantastic based upon multiple threads I found here on the topic.
One number is 21001594 as found here:
http://www.transpartsdirect.com/shop...1-up-21001594/
The other is 21003314 as found here:
http://www.saturnfans.com/forums/sho...d.php?t=184798
Depending on what Google or forum searches I do.
Just wondering if these are two numbers for the same part that may have changed over time or if they only fit certain years/transmissions.
Thank you!
Add to gas3987's Reputation
Rate the quality of this post and help gas3987 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gas3987 is offline   Reply With Quote
Old 12-06-2018, 01:18 AM   #2
Default Re: TAAT sprag clutch part number and where to buy
21003314 is the good number. Depending on the year and type of the transmission this can be much more involved than just a sprag clutch replacement.
Changing to a full synthetic trans fluid may solve the issue without opening up the transmission.
I think with the 99 MP-7 trans it is a drop in. Check your transmission year though.
TAAT sprag clutch replacement saturny S-Series Tech 3 11-20-2014 07:22 PM
'01 SL1 Transaxle 1st Clutch Sprag / Oil Pump jjbrudvig S-Series Tech 4 09-24-2012 07:39 AM
l-series clutch "pigtail" part number axls L-Series Tech 0 05-12-2008 01:51 PM
1st Gear Sprag Clutch pjkelnhofer S-Series Tech 6 03-15-2006 06:34 PM
Clutch Slave Sylinder S-Series Part Number? cris_thomas S-Series Tech 5 09-21-2004 05:24 PM
