Old 03-01-2018, 06:07 PM   #1
Purplebrakes
Purplebrakes is on a distinguished road
Default Rpmís
Wondering what peopleís rpmís run at at 70mph. My 96 sl1 runs at 3k rpm going down the highway at 70mph. Wondering if thatís normal?
Add to Purplebrakes's Reputation
Rate the quality of this post and help Purplebrakes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Purplebrakes is offline   Reply With Quote
Old 03-01-2018, 08:09 PM   #2
hholbein
1997 SW2
Default Re: Rpmís
Is this a manual transmission? If so:
3K rpm @ 70mph/110kmh is normal for the transmission that originally shipped with the DOHC version. If your ride really is an SOHC, the factory transmission would probably show 2500rpm @ 70 -- it's geared taller. It's possible a prior owner swapped in a DOHC transmission for the original.
Add to hholbein's Reputation
Old 03-01-2018, 08:26 PM   #3
sc2 saturn
sc2 saturn is on a distinguished road
Default Re: Rpmís
yup thats about what my runs at my is a 01 sc2 dohc 5spd and it runs at 3k-3100 around 112kmh
Add to sc2 saturn's Reputation
Rate the quality of this post and help sc2 saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2 saturn is offline   Reply With Quote
Old 03-01-2018, 08:42 PM   #4
Saturn Night
Saturn Night is a jewel in the roughSaturn Night is a jewel in the roughSaturn Night is a jewel in the rough
Default Re: Rpmís
My 1995 SC2 pushes the 2,800rpm mark, at 70mph. I have the 4-speed Auto.
As far as what is "normal" rpm for these cars, it depends on transmission gearing, final drive ratio, and tire/wheel diameter.
I have stock 15" teardrop alloy wheels, stock tires, and a stock gear set.
I can list my car, as a reference:
Final Drive: 4.133:1
4th Gear: 0.700:1
Tire/Wheel Diameter: ~23.74in.
Estimated Engine RPM @ 70mph: 2869rpm
http://spicerparts.com/calculators/t...rpm-calculator
Old 03-04-2018, 01:48 PM   #5
Purplebrakes
Default Re: Rpmís
Itís a DOHC automatic. I have no clue if the transmission has ever been swapped. It was parked for a few months due to an issue that I procrastinated fixing. I just started driving it again and thought 3k rpm was high for 70mph. I seem to remember(but not 100% sure) it being at 2500 rpm at 70mph when I was driving it before. Didnít know if 3k was normal, or if it was not going into overdrive or 4th causing it to run at 3k.
Old 03-04-2018, 03:47 PM   #6
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
Default Re: Rpmís
Saturn Night said "
My 1995 SC2 pushes the 2,800rpm mark, at 70mph. I have the 4-speed Auto."
I took special notice yesterday to watch mine, so I now can say:
"My 1996 Sub pushed the 1,800 rpm mark, at 70 mph. I have a 4-speed Auto"
---- altho, the Sub is a 350 vortec Suburban. 1,600 rpm at 60 mph
Old 03-04-2018, 11:13 PM   #7
Jonasan308
Jonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of lightJonasan308 is a glorious beacon of light
Jonasan308's Avatar
1999 SC1
Default Re: Rpmís
2500 at 70 mph is normal for my automatic SOHC. Id be spinning like 3k at 80 mph
1999 Saturn SL1-129k at purchase(may 2016)-139k when wrecked(September 2016)
1999 Saturn SC1(CURSED)-156K at purchase(october 2016)-181k currently (apr 2018)
Dodging potholes should be a sport
Add to Jonasan308's Reputation
Rate the quality of this post and help Jonasan308 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jonasan308 is offline   Reply With Quote
Old 03-05-2018, 07:18 AM   #8
Purplebrakes
Default Re: Rpmís
I have to set the cruise at about 62mph to be as low as 2500rpm.
Old 03-05-2018, 10:21 AM   #9
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
Default Re: Rpmís
I love the SL2 gearing on the highway. At 70 I am turning 3000. If I need to pass or climb a hill there is no shifting required. It still has zip.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 03-05-2018, 10:41 AM   #10
Purplebrakes
Default Re: Rpmís
So what makes some run at higher rpm and others at lower rpm? I still donít know if itís normal for mine to run that high..
Old 03-05-2018, 12:39 PM   #11
Jonasan308
Jonasan308's Avatar
1999 SC1
Default Re: Rpmís
Hmm. What kind of tires are you running? I have 185/70R14. Tire size and wheel size has something to do with it as well.
Old 03-05-2018, 06:31 PM   #12
Saturn Night
Default Re: Rpmís
Originally Posted by toggenburg View Post
Saturn Night said "
Your Suburban also has a much taller rear-axle ratio(Final Drive Ratio), probably 3.23:1 as the 4L60E transmission has a 0.700:1 4th Gear Ratio(Which is identical to the 700-R4 that was replaced by the 4L60E transmission in those models).
Old 03-05-2018, 06:35 PM   #13
Saturn Night
Default Re: Rpmís
According to your initial post:
So, which is it?
And to clarify whether the transmission has ever been swapped:
The PCM has calculations for the gear ratios of the automatics.
If the taller, MP6(Sx1 transmission) is swapped into an Sx2 car(or vice versa), the car will have no gears due to all 4 gears sending DTCs for "Incorrect Ratio".
Old 03-05-2018, 08:55 PM   #14
Purplebrakes
Default Re: Rpmís
So, which is it?
So what is what?
Itís a 96 sl1 DOHC with an automatic. The tires are 185/60R15.
Old 03-06-2018, 09:19 AM   #15
Saturn Night
Default Re: Rpmís
So what is what?
Did you read my last response, about the differences between an Sx1 and an Sx2 Saturn S-Series?
Old 03-06-2018, 01:09 PM   #16
Jonasan308
Jonasan308's Avatar
1999 SC1
Default Re: Rpmís
96 SL1 DOHC?
As in, you have an SL1, with grey bumpers, but undernearth the hood sits a DOHC engine with the black valve color. With the DOHC automatic transmission?
The biggest difference between the transmission of the SOHC (SL1/SC1/SW1) and the DOHC (SL1/SC2/SW2) Is the gear ratios being shorter on the DOHC for performance. This will also mean higher revs on the highway. If you really have a DOHC than your revs sound about right.
Also, how high can your car rev?
Old 03-06-2018, 07:17 PM   #17
Purplebrakes
Default Re: Rpmís
96 SL1 DOHC?
No, I have color matched bumpers. And yes the valve cover is black. I have no clue if itís the original transmission or not. Itís been in the family for around 8 years or so and I do know that a different transmission has never been put in it since it was bought by my dad.
Do they put DOHC in SL1ís? Because according to what you typed i take it as they do.
The tach says redline is at 6500. Iíve never tested it to see if it goes higher.
Old 03-06-2018, 07:31 PM   #18
trottida
trottida's Avatar
Default Re: Rpmís
Do they put DOHC in SL1’s? Because according to what you typed i take it as they do.
The tach says redline is at 6500. I’ve never tested it to see if it goes higher.
No, the DOHC only came in the SL2/SC2/SW2 S Series. The SOHC went into the SL/SL1/SC1/SW1. The 1991 SC is an anomaly and only came with a DOHC. The 6500 redline is indicative of a DOHC engine. I'm pretty confident that you have an SL2 and if it says SL1 on your ownership then it is wrong.
SL2 would also have better seats with height and lumbar adjustments, a rear deck panel that would make the rear lights appear to go from side to side (as opposed to body colour between), painted door handles & bumpers, rear sway bar, a beefier front sway bar, tachometer with a 6500 redline and the DOHC engine would have the plugs across the centre rather than on the front edge as does the SOHC.
Current rides
2001 SL1 MT (410,500 km @ 11/2017)
1999 SL2 MT (251,500 km @ 11/2017)
2011 Suburban LT (101,450 km @ 11/2017)
:canada:
Add to trottida's Reputation
Old 03-06-2018, 07:34 PM   #19
Saturn Night
Default Re: Rpmís
No.
https://en.m.wikipedia.org/wiki/Saturn_S-Series
As quoted: "The 1 or 2 (or lack thereof) in the model designation signifies which engine the vehicle has, and transmissions were kept specific to each engine. All S-Series used either the SOHC LK0/L24, or the DOHC LL0 version of the completely original, designed in-house Saturn 1.9L engine. Logically, the 1 designates a vehicle with an SOHC engine, whereas a 2 designates a vehicle with a DOHC engine. SL and SW models with no number are base models, with all manual options and the SOHC engine."
Old 03-06-2018, 08:11 PM   #20
Jonasan308
Jonasan308's Avatar
1999 SC1
Default Re: Rpmís
There we go. So, according to that, you have an SL2. In that case, 3000 RPM at 70 is normal for your car then because you have the shorter ratio transmission.
