Old 03-14-2018, 01:28 PM   #21
hholbein
Default Re: Rattle @ idle only under load (A/C)
Originally Posted by fullyloadedSL2 View Post
Always use OEM belts and tensioners with these cars. Aftermarket tensions rarely last more than a year. I replace cheap tensioners like clockwork. OEM lasts 10x longer.
+ 1 on OEM tensioners. I've had the bearings wear out before the tensioner, and those can be replaced quite economically on the Gen-2 versions with metal pulleys.
I've had quite good luck with Gatorback belts keeping things quiet.
And I did have a waterpump bearing noise that had me worried that it was the AC clutch -- until I put on a shorter belt to take it out of the circuit and voila -- the noise was still there. Isolating noises to their root cause can be challenging, but it's worth your time trying the cheap approaches first. If my timing chain started to go, I'd sell/scrap the car. Too much hassle on a 21 year old car.
Add to hholbein's Reputation
Loping idle under load RHD SW1 S-Series General 6 03-04-2011 11:35 AM
Rattle Noise From Exhaust System Under Slight Load steelerfan4life Vue Tech 12 01-15-2008 09:10 AM
Rattle under load Scout238 S-Series General 19 05-19-2006 10:30 AM
23% load at idle? eljefino Miscellaneous Tech 4 04-03-2003 11:28 AM
Question about engine vib when idle under load Stormgirl_LP L-Series General 4 01-14-2003 10:08 AM
